Question about Acer Aspire L100 PC Desktop
Acer Aspire Mini PC
I wonder if the Motherboard in this nice device (L100, L320) is a "standard pc" Intel motherboard, that can be replaced with any mini pc motherboard, or is it an Acer propriatry device.
please advice, or provide more info about the motherboard...
thanks in advance,
Yaron
  • hereof Oct 15, 2007
    thanks for your answer,
    my question is about the Acer motherboard, do they manufucture their on boards, or do they use a standard mini ATX?
  • Anonymous Mar 22, 2014
    I would like to have a manual for motherboard Acer Aspire M5300.
    Acer part number MB.SBU09.003
    Or FRX780F ATI RX780 SB710Marvell8071x6
Looking inside an L100 right now. It's not a micro ATX or mini ITX format size, it's proprietary. Good news is that it has a mini PCI slot and space for a low-format mini PCI card.
Posted on Feb 10, 2008
    Novelist:
    Champion:
  • 231 Answers
Hi, you will be able to purchase a mini ATX format board by almost any manufacturer that will fit the acer case, the only problem you may hve is the PCI and Graphics cards will need to be low profile standards but these are also available if you are not planning on gaming then the on board graphics on most new boards will do all you ask of them.
Regards mistyman
Posted on Oct 15, 2007
    Problem Solver:
  • 10 Answers
Goto www.lavalys.com & download the ffree trial version of Everest. This software allows you to scan & diagnose the exact system details, motherboard/chipset etc..With this info you can then search for the exact items that are needed. Hope that helps
Posted on Mar 15, 2008
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I have a acer aspire m1640, with the motherboard fails, if i can not fix it, what motherboard, acer apart, can i mount it? thank you
    There are a few options you have on this, but if you want to maintain full compatibility with your current hardware, then you must purchase a motherboard that supports DDR2 533/667 MHz SDRAM since that is what comes standard in Acer Aspire M1640 Desktops.
    A few options that would be similar to stock motherboard would be:
    Foxconn G31MXP-K I7 or Biostar TForce TG31-A7
    Those motherboards have similar specs to the stock motherboard and you can take a look at the specs of the Acer Aspire M1640 from this link below:
    http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM1640/AspireM1640sp2.shtml
    Both those motherboards I have linked you too are microATX boards, which should fit fine in your case which may be a standard ATX case.
    If you are willing to upgrade your ram, then your options open up to any motherboard that supports the Intel Pentium Dual Core processor. Since the stock motherboard also provides onboard video, chances are you don't have a video card plugged into your motherboard (unless you've upgraded that yourself) which means you should also look for a motherboard that provides onboard video so you don't have to purchase a video card.
    Feb 26, 2011 | Acer Aspire M1640 Refurbished Intel...
    The acer l100 does not power on at all no lights or fan running
    If the computer is not starting then and the power supply is ok then you need to try a different charger. If the problem still exist this may a sign that the motherboard is dead and need to be replace, because when a motherboard is dead it the computer will not receive any power.
    Thank you
    May 16, 2010 | Acer Aspire L100 PC Desktop
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    Another owner of the acer L100
    For L100 drivers, go to the acer website and download them. There is also a link to order a disk to reload the OS.
    http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
    Aug 04, 2008 | Acer Aspire L100 PC Desktop
    Where can I get a replacement motherboard for an Acer Aspire L-100 Mini Desktop
    The board is proprietary and no similar size boards exist. Acer has such bad customer service (lied and mislead me for months, then demanded $500.00 just to look at it) that I have chosen to scrap the unit rather than try other possible sollutions (larger case with different board, cracked solder joint detection, etc.)
    Jul 24, 2008 | Acer Aspire L100 PC Desktop
    Aspire Motherboard... again..
    No the Acer is no manufacture the board
    Oct 16, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    694 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
