Question about Philips Televison & Video
No power at all, checked all outlets and plugs, called for warranty info, OUT OF WARRANTY, service center thinks it may be the power supply box, based upon my description over the phone? Is this a part I can order and replace myself?
  • 431 Answers
A replacement Power supply unit is probably available however I have to wonder what caused it to fail in the first place , with most things cause and effect is a main consideration .
whilst this new supply may bring your set back to life I have to wonder for how long ?. Phillips power supplies are noted for being fairly robust and forgiving so this makes me think that you have possibly a bigger problem ?. Should you wish to contact philips direct the company is called Combined Electronic services ,and the european headquarters is in Croydon London .
I should also like to point out that repair of the Power supply by a qualified engineer would probably be far cheaper than replacement and quicker . I hope this is of help to you Regards Vortash
Posted on May 13, 2009
How and where do I send my tablet for repair?
I'd think it would depend on a few things:
-is it under warranty? if so, ship it where the warranty tells you to for service.
- not under warranty? go to the manufacturer's website. There should be service info there.
Sorry I couldn't be of more specific help.
Feb 03, 2016 | Tablets & eReaders
HP Photosmart D7360 printer will not power-up for more than a few seconds; turns itself off.
Is the printer plugged into a power strip, or is it plugged directly into wall power?
Aug 11, 2008 | Televison & Video
Power switch tv is black wont turn on
Sounds like a power supply issue. If the TV will not turn on, make sure the plug is in the outlet firmly. Try to unplug for an hour and then try again. If not you will need to have the TV serviced by an authorized provider. If it is under warranty try calling Sony. If not I would probably recommend replacing the TV as it can cost hundreds for service calls.
Apr 09, 2014 | Sony BRAVIA Televison & Video
The power will not turn on? The green light on the back is flashing, but nothing will trun on. how do i get it back on?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have located the manual, click or copy paste to download the manual for future reference.
Getting Started Guide 9.11M http://h10032.www1.hp.com/ctg/Manual/c00230513.pdf
From the manual : Power - Troubleshooting page 101
QUOTE
Symptom: PC will not turn on or start.
Problem: PC is not securely connecte
Solution: Ensure that cables connecting the PC to the external power source are plugged in properly.
Problem: Green power supply light on back of PC is out.
Solution: When the cables connecting the PC to the external power source are plugged in properly and the wall outlet is functioning, the green power supply light should be on; if the light is not on, refer to the Warranty and Support Guide to contact Support.
Problem: Monitor is not connected or is not on.
Solution: Connect the monitor to the PC, plug it in, and turn it on.
Problem: Line voltage selection switch is not in the proper position for your country/region (115V/230V).
Solution: Set the line voltage selection switch to the correct setting for your country/region, or refer to the Warranty and Support Guide to contact Support.
Problem: Wall outlet is defective.
Solution: Test the outlet by connecting a different electrical device to the outlet.
Problem: Wrong memory modules were used in an upgrade, or memory modules were installed in the wrong location.
Solution: Reinstall the old memory to return your PC to its original state. Refer to the Upgrading and Servicing Guide for instructions.
Problem: Hard disk drive is damaged.
Solution: Press the Help ? button on the keyboard to open the Help and Support Center, or refer to the Warranty and Support Guide to contact Support for replacement details.
Problem: After an upgrade or repair, the drive power, data, or power supply cables may not be properly connected.
Solution: Reseat drive power, data, and power supply cables. See the Upgrading and Servicing Guide for instructions.
UNQUOTE
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | HP Pavilion a749c PC Desktop
Brother mfc-440cn has error unable to print 4f
The service manual says it could possibly be a bad Main Board or a power supply problem, but it always turns out to be a broken printhead. If it's under warranty (one year) get to an authorized service center and Brother will cover all the costs except your time and gas. If it's just past warranty, call Brother's customer support and beg. Sometimes they issue work orders for warranty service on machines that are past their warranty.
If it's out of warranty, I'd recommend giving up on it. The parts are expensive, it's time-consuming (expensive), and you can buy a replacement machine pretty cheaply. www.BrotherMall.com lists refurbished, more advanced machines for $90.
Sep 20, 2010 | Brother MultiFunction Center MFC-440CN...
Mp830 all in one one month out of warranty lost power on its own this a.m.. Unplugged for several hours, no response. have checked cord/outlet just fine. repair center is 150 miles away. anyone have a...
well as they say they only build them to last until the warranty wears off. if the power supply is making a whining noise it might have blown. either you could buy a new one or as you said the repair center is 150 miles away.......
Mar 12, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Samsung lcd tv won't come on red light flashes
good day..
i think you need to access the power supply circuitry.. and find leaky capacitors.. most likely only the capacitor get defective right after the one year warranty..
but if it is.. then do not open it.. and call service center if you can.. for a free service warranty..
god speed..
Jan 02, 2010 | Samsung LN19B360 19 in. TV
TV will not power on. Checked outlet and that is
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Xerox Documate 152
Hmm, well no, just the basics of checking all the wiring. Hope it was within warranty.
Aug 05, 2008 | Xerox DocuMate 152 Pass-Through Scanner
Panasonic Plasma died. Model TH42PX60U purchased Jan. 2007
In the majority of cases when you'are unable to power up the TV, the power supply would the first place to start.
Check this site for cheaper power supply.
Good Luck.
Apr 04, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
