Question about Acer AL1916W 19" LCD Monitor
Monitor lcd acer al 1916 half the screen is white
  • Anonymous May 13, 2009
    my monitor at times is normal and sometimes get the screen split inhalf on the right screen with some white vertical stripes, theright-hand half of the normal image acer al 1916
    Sergeant:
    Champion:
  • 201 Answers
Theres 2 PCB on the side working one of those is faulty
Posted on May 13, 2009
Acer 1916 monitor..Power button flashing but won't turn on
Look for bad caps in the power supply first, post back what you see inside so we can guide you furhter, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 10, 2010 | Acer AL1916B 19" LCD Monitor
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
A virtical squash - (not talkin veggie)
I solved it by adapting myself mentally to the fact that it's only a little squashed. I'm used to it now.
'Not exactly what most people can use as a template, but there's other things to invest my emotions on.
Dec 04, 2008 | Acer AL1916W 19" LCD Monitor
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
AL 1916 s
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
My moniters screwed
Sometimes this is due to graphics cards, but most of the time it is due to drivers. If it does not happen when you are using your PC for other things the problem probably just lies with the graphic card, driver, and this particular game or any game similar. Drivers are the most notorious! Check your requirements on the game for graphics cards recommendations! Let me know!
Oct 10, 2007 | Acer AL1916W 19" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
381 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
