Question about Sharper Image GM402 CD Shelf System
Cd cover doesn't open
I have a Sharper Image GM402. When I push the button to open the CD player, nothing happens. The radio works. Bought it some years ago, during move... NEVER played it. Just dug it out and would LIKE to be able to play a CD. Ads say it is a motorized CD cover, does it pop up or slide back, I'd like to assist it along, but trying to avoid breaking it.
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
Posted on May 14, 2009
CD player wont work. Any suggestions
Instructions
  1. 1 Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
  2. 2 Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
  3. Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
or try going to this link might help you out. CD player wont work Google Search
Dec 14, 2016 | Sharper Image Audio Players & Recorders
No Disc error
Hello
Clean the lens assembley of the set by inserting a lens cleaning disc into it , and play it at least three times. If it does not help you, the laser pickup unit of the set is faulty and should be replaced with same type and number. The cleanind disc can be bought from electroncic spare part selling shops at your town, and won't cost more. OK.
Jan 19, 2012 | Sharper Image GM402 CD Shelf System
I have a Sharper Image Blue Night CD Player with a motorized CD cover that automatically slides up or down (to play CD) at the touch of a button. When I push the button to close the door (and play CD),...
I would first check to see if there is something that is obstructing the door, and if you cannot find anything, then you could take it to any electrical repair shop, and they could fix it for you.
Mar 26, 2011 | Audio Players & Recorders
Cd in player, says NO DISC
try unplug cd player and reconct
Oct 09, 2009 | 2005 Pontiac G6
Sharper Image 3-CD model SA248 Doors opening problem
The bands that allow the cogwheels to turn, snap and needs to be replace.
Sep 10, 2009 | Sharper Image Audio Players & Recorders
Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Jun 16, 2008 | Sharper Image SA260 CD Shelf System
Sharper Image GM402 CD Shelf System Logo
219 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
