Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I need to clean grass from under mower
How to clean under mower
    President:
  • 1,489 Answers
If it's your standard riding or pushmower, do this:
Put it up on blocks and use a putty knife to scrape out the grass clippings. You can just put two wheels on blocks, makes access more difficult, but still doable -- however, don't turn the machine over.
Another approach is to use a garden hose -- not my favorite method.
Posted on May 13, 2009
Mower runs but low idle cleaned carb fresh gas and cleaned and gapped plug what else would cause this issue?
Did you remove the bowl under carb. and clean.A bolt holds it on with a rubber washer,trash gets in their and gives the carb, problems.It's good to add a inline gas filter with a cut off valve.
Jun 13, 2015 | Garden
Why does my spirit 41 electric mower keep switching off?
the engine heat is overloading and shutting off clean all the grass under the mower once thats done should be ok
Aug 24, 2014 | Garden
Snapper mower 42 inch with brigg stratton vanguard 16 hp v twin engine lopes when not under load
I would start by cleaning the air filter and the spark plug, or replace both if they are old.
Aug 08, 2014 | Briggs & Stratton Garden
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
The mower starts easily but loses power and stalls out
You may need to adjust the fuel mixture screw on the carb to allow more fuel under load. And check to see if air cleaner is clean.
Apr 20, 2010 | Mtd 22" Yard Machine Push Mower
Push mower blows gas out muffler
Your needle valve under the float jet in the carb is stuck.
You need to pull the carb apart and clean the needle valve under the float.
With it in the stuck open position, your gas will flow to the carb air intake and flow out onto the deck of the mower.
Sep 25, 2009 | Craftsman Garden
My lawn mower cranks but wont start I have
The magnets are fitted in the flywheel under the pullstart engine cover but i dont think thats your problem. It sounds more like fuel trouble. Remove and clean out the carb. and maybe renew the diaphram.
Sep 05, 2009 | Garden
How do you clean under the cutting mechanisam,to clear out the old grass that has built up.
get a pliers and start pulling keys out from under the tractor if you can make the mower go up pull it up and remove anything from the tractor to the mowerand your going to have to flip over the mower
Sep 02, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Lawn boy 2 cycle that smokes
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Jun 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
82 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
