Question about HP Photosmart C6180 All-In-One InkJet Printer
Cannot print any text
Error oxc19a0013
  • 433 Answers
Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
Posted on May 13, 2009
I have an HP and it says ink system failure Oxc19a0013 what does that mean.
remove the catridges and then unhook the print head. wipe with soft cloth. otherwise you need to replace print head
Aug 01, 2016 | HP PHOTOSMART PLUS B209A All-In-One...
Hp photsmart 8250 system failed error code Oxc19a0013
According to the HP website, this error code means the ink system has failed, and the unit will need to be serviced by an authorized HP repair technician - An Ink System Failure or 0x Error Message Displays on the HP Printer...
However, you can try resetting the printer first -
Reset the product
  1. Without turning off the printer, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the printer, and then try printing again
  10. If the reset fails it will require a service.
  11. NOTE: if you are using refilled or remanufactured cartridges try the reset with genuine hp cartridges as they will be recognized as original authentic HP cartridges by the printer
Apr 13, 2015 | HP Office Equipment & Supplies
Ink system failure Oxc19a0013 HP Photosmart B110
Check all of your cartridges to ensure that all of the protective tape has been removed. If you still receive the message after the check then power down your printer and remove the power cord from the back of the printer. Remove all of the ink cartridges from the printer. Wait 2 minutes, then plug the AC cord back into the printer. Turn the printer back on. Once the printer goes through it's power on self test it will ask you to insert the print cartridges. Go ahead and do so. If the error message does not display itself then you are okay to go ahead and use the printer. However, if you still receive the error display then you will have to have the printer serviced. Unless you have the tools, experience, and a copy of the service manual for your printer, it is best to have your local HP repair center take a look at the printer. The code signifies an ink system error, but there are a number of reason that can cause the error to display.
Mar 13, 2011 | Office Equipment & Supplies
I have a system failed error code Oxc19a0013
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord
Jul 10, 2010 | HP Photosmart 3310 Printer
Error message #Oxc19a0013----Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printronix T5000r Label Syntax to print " character
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Jul 14, 2008 | Printronix T5000r Label Printer
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
401 people viewed this question
Seeker5211
Seeker5211
