We have a Kenmore Elite Oasis Washer. At the beginning of the rinse cycle we get an "F1" error. I hit the "stop" button" then "start" again and it finishes the wash fine. This just started happening. My husband took the machine apart, thought he found the problem but it's still happening. What does "F1" mean?
  • 2 more comments
  • dchenkus May 13, 2009
    Perfect. I'll have my husband try this tonight!
  • dchenkus May 14, 2009
    Good Morning Kevin,
    My husband did what you suggested - here's what he got:
    88 appeared for 3 seconds
    C0 - 1 second
    C1 - 2 minutes
    C2 - 10 seconds
    C3 - 10 seconds
    C4 - 10 seconds
    C5 - 15 seconds
    C6 - 15 seconds
    C7 - 1 minute
    C8 - 3 seconds
    There was no display F-60 through 68. I ran the washer on a regular load afterwards and it still gets jammed up with 17 minutes left in the cycle. I had to hit the stop button and then the start button (two times) and then the cycle finished. Any suggestions?
    Diane
  • dchenkus May 15, 2009
    We're now getting an "F68" with 17 minutes left in the cycle....is this because the control board needs to be replaced?
    I can't read the instructions to change the control boad - can you resend them?
    Novelist:
  • 151 Answers
If you take your console off there are 2 boards on the back--- ensure all connections to each other are good--- the one to the right is the motor control board and the one to the left is the machine board. its just simple.you will have to connect the wires in the new board as connected in onld board.so mark the wirings in old board properly before removing the old board. you will get the control board at  www.repairclinic.com and or at  www.partsselect.com
thanks.keep updated.
Posted on May 15, 2009
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components. There is a slight possibility that a problem with the pressure switch hose could be causing this problem. A pinched or twisted air hose can cause this fault code. When you open the console, check the air hose connected to the pressure switch on the machine control board. If it is pinched or crimped, I recommend rerouting the hose to resolve this problem. This may fix your problem without replacing the control board. NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit. If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
If you reply using the "Continue with this expert" option - I can assist you in ordering the correct part.
Thanks for using FixYa!!
Posted on May 14, 2009
  • blueextc3221
    blueextc3221 May 15, 2009
    click on the link provided HERE
    Mouse-over the picture, and if you click it - you can enlarge it.
    Or save it to your hard drive and use any photo viewer to zoom in.
  • 483 Answers
Do let us know & share your feedback with us. The ratings help us grade the level of service.
Thanks
Fame !
Posted on May 13, 2009
    Genius:
  • 1,847 Answers
Here is one step I found for this error code:
With the washer plugged in and all indicator lights off, select any key except power, start and stop.
Press hold for 3 seconds, release for 3 seconds, press hold for 3 seconds, release for 3 seconds, press hold for 3 seconds. If you did it right all indicators will light and 88 will appear in the display. If there are any faults, they will then display, look for a F-60 through 68. This will confirm the board is corrupt. If no faults are found the machine will go through a five minute automatic test cycle.
Let me know what happens after this.
Thanks
Kevin
My washer says F1 about 6 times before it will start. I have to stand there and hit the pause button 6 times before it goes into the cycle. Then when it is ready to rinse, it will say F1 again. Is this...
It is most likely the main control board. They have been having alot of problems with that machine flashing F1. They did a recall on the main control board on some of those washers. You might want to call the manufacturer to see if your machine is one of them.
Jul 11, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Error code F1 on Kenmore Elite "Oasis" clothes washer
Instructions Press "Stop" to clear the current cycle on the washer.
  1. 2
    Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
  2. 3
    Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
  3. 4
    Select the desired wash cycle and press "Start."
Dec 12, 2010 | Washing Machines
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
