Question about ViewSonic E70fb 17" CRT Monitor
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
  • 77 Answers
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
Posted on May 13, 2009
My monitor(view sonic e70fb ) is osd lock, n how how can get unlock
Hi Mandalavijay,
To unlock your monitor you need to hold two keys simultaneously for about 5 seconds.
In this case for your model you need to press the 1 key and the down arrow key and a message will appear which reads ' OSD Unlock'
Hope this helps...:) Your feedback would be appreciated.
Aug 22, 2011 | ViewSonic E70f 17" CRT Monitor
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
Osd lock popup and maina menu popup is continously blinking on my monitor screen plzzz help me how can i remove it? i have view sonic monitor E70FSB...plzzz help me out
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..
in case case of 45Bn & 55V..look for Controller Reset IC201/IC202 (KA7045/KA7045AP) [it is a small alike transistor 3 pin IC !!] along with the afore said..
and in case of 56V..look for +14V SW. Transistor A1281 & C945 (therein) along with the afore said..
..beware u must b a professional..
contact ur system admin/vendor....
Nov 02, 2009 | Computers & Internet
View sonic monitor gets contrast/brightness blue box in middle of screen
Its an issue with the OSD menu button or the circuit, tap the button a couple of times, it may resolve the issue as it may free up the jammed button. Else its a circuit issue, also check any loose connections. It may need a repair.
Regards,
Shrey
Oct 09, 2009 | Computers & Internet
At the centre of my viewsonic monitor model:E70fB a message in blue coloured box that"osd lock"and its blinking continously its irritating me
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
May 14, 2009 | ViewSonic E70fb 17" CRT Monitor
Message blinking at the centre of monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
You will find that and other information in the manual located here. The above information is found on page 7.
Hope this helps. Please remember to rate this information.
Thanks
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
OSD automatically displays and I can't rid of it. Monitor display adjustments are being made and I can't control it. Sometimes it's like this. Sometimes it's OK. I am having this problem for months...
My view sonic monitor E70fB Model. Without I Press the menu, it always appearing on the Screen. Some times Contrast up/down and osd lock and it suddenly scrollsfor other options.
If I press the exit button, it sometimes exits or agin it occurs.
So please kindly solve this problem
Dec 06, 2008 | ViewSonic 17" CRT Monitor
Osd lock
Dear srinivasvodn,
Press the menu button of your monitor for a wile OSD lock will unlock.
Aug 05, 2008 | ViewSonic 17" CRT Monitor
ViewSonic E70fb 17" CRT Monitor Logo
436 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
