Question about ASUS Z91N Barebone
Windows corrupt and driver set
Friends,
My Asus machine just prompted me with 2 problems.
I was using two windows XP on my system. First one was a Japanese Windows XP and the other was a XP professional.
The Japanese OS had all my documents and other personal data stored in MY Documents folder which was Password protected. Now, My Japanese Window is corrupted and I can no longer use it. I dont have its CD so cant repair it as well. Also, the biggest problem of all is that I cant access my documents, including the driver set for ASUS Z91E which was saved in the same password protected MyDocument in Japanese XP.
Is their any possible way to save my data from the other operating system which I can currently use? Also, can any one help me to attain the drivers for ASUS z91?
I will be extremely thankfull for any kind of support.
Asim
  • salahdin Oct 15, 2007
    Dear,
    Thanks for the quick reply.
    I can locate my MyDocument folders on my C drive. The problem is that I cant access them because it an error prompts "Access denied". I have two different Administrator accounts for the 2 windows and I know the passwords of both, but the Japanese administrator doesnt sign in on English version.
    Hoping for further assistance.
    Asim
    Brigadier General:
  • 6,966 Answers
Re your queries:
1. "Is their any possible way to save my data from the other operating system which I can currently use?" - possibly
2. Also, can any one help me to attain the drivers for ASUS z91?
Most of the needed drivers for an Asus Z91E are available at the Asus Website > http://support.asus.com/download/download.aspx?SLanguage=en-us&model=Z91E
Most corrupt files in Windows would not delete your Japanese My Documents. What would probably be gone would be ntldr, hal, various dlls and sys files but most of your .doc would remain intact.  If you can boot using the English Win XP Pro and presuming you have 2 different usernames 1 for the Japanese and another 1 for the XP Pro, then chances are that you can still access the Japanese My Documents. It may not be shown but it should be there under the Japanese username.
Assumng you have administrator privileges, Click on Start, Control Panel, Folder Options, View, tick: Show hidden files & folders, untick hide extensions for known file types, untick hide protected operating system files.
This should expose what were hidden before. Of course it is a different problem altogether if you have the 2 OSes installed on 2 different partitions.
Hope this be of some help. Post back how things turn out or should you need additional information.
Good luck and kind regards.
Posted on Oct 15, 2007
  • Louie  Role
    Louie Role Oct 16, 2007
    Offhand, what I can suggest is to remove the hd (with 2 windows) and install it as a slave on a second PC. You can try accessing it from there then. Copy the Japanese My Documents to the English My Documents under another folder name.  Since the 2nd PC will be running its own OS, chances are it will not require passwords for the Jpn My Docs.
    Connecting the Jpn/Eng HD to a 2nd PC could be done with an external IDE/SATA to USB adaptor or internally IDE/SATA cable.
    Cheers.
SOURCE:
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Asus p4sgx-mx audio driver
  • Model: P4SGX-MX
  • Size: 2.09 Mb
  • Date added: 16-Apr-2009, 07:43
  • Manufacturer: ASUS
  • Device type: Motherboard
  • Operation system: Windows XP
  • MD5: cc496c9fc693f22e1e02bccfcc0e91b9
  1. http://nodevice.in/driver/P4SGX-MX/get54804.html
  2. http://www.nodevice.com/driver/P4SGX-MX/get54804.html
  3. http://www.driversberry.com/drivers-P4SGX-MX-fGpKoZZ1US.html
Asus P4SGX-MX Audio drivers
Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3665 File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3620 File size: 18 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3533 File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 4.2.0.82 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3620 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3533 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Check out this page for a P4SGX-MX Audio driver download. Here you may choose your Asus device driver software. Please keep in mind that you should choose a proper P4SGX-MX Audio Asus device driver. First of all you should know your operating system, vendor name and device model. If you don't know what device you have inside try out this. Try to search for your device driver using PNPid. Open Control Panel-system-hardware-device manager then double click and click details. Use this long digits and letters line to find out what device you have and driver for it. Some drivers on our website may be packed with winzip or winrar programs.
Sep 19, 2011 | ASUS P4SGX-MX Motherboard
Windows xp is not starting
Windows XP is a fairly stable and secure operating system, but errors and other problems will occur from time to time. Unfortunately, some of these errors can damage or corrupt important system files and can lead to Windows XP not booting up correctly. You can repair your Windows XP installation using a process known as a "repair install," overwriting the damaged system files with new versions from your Windows XP installation disc. The repair install process takes approximately one hour, though a large portion of this time will not require any input from you.
1,Start your computer and place the Windows XP installation disc in the drive. If the computer is crashing upon attempting to boot, allow it to restart; otherwise, reboot the computer manually.
2.Press a key to boot from the Windows XP CD if prompted to do so when the computer attempts to boot again. If you are not prompted to boot from the CD, restart the computer again and press the indicated key on the initial BIOS screen to access the "Boot Order" or "Boot Sequence" menu. Select the CD or DVD drive containing the Windows XP installation CD, then press a key when prompted to boot from the disc.
3.Press the "Enter" key on the initial Windows XP welcome screen and press "Enter" again to begin setting up Windows XP. Do not press the key indicated to launch the "Recovery Console," as the Windows XP recovery console is not used to repair corrupted XP installations.
4.Accept the user agreement and wait while the setup program scans your hard drive.
5.Press the "R" key when the Windows XP setup program lists the installed version of XP that it detected to begin the repair installation. If you have more than one version of Windows XP installed, make sure that the proper version is listed before pressing "R."
6.Wait while the Windows XP setup program copies files to your hard drive and begins the installation process. The installation will take 45 minutes or longer, depending on the speed of your computer, during which time all of the Windows XP system files will be overwritten.
7.Confirm your user information as well as the date and time settings on your computer, and enter your Windows XP product key when prompted. Allow the operating system to connect to the Microsoft authentication servers to activate itself.
8.Reinstall any hardware drivers and XP Service Packs that you had previously installed, as your copy of Windows XP will have reverted to the basic installation you had when it was first installed.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
NTLDR is missing
Insert and boot from Windows XP CD just as if u want to do a new installation entirely
1- If it detects the operating system - just do a repair
2- If it fails to detect the initial operating system
- Restart and allow the CD to run
- In the first Dialog window press R (Recovery Console)
- then type CHKDSK /p /r at the command prompt
Sep 08, 2010 | Microsoft Windows XP Professional With...
I am having trouble running setup on my desktop
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for...
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Jan 21, 2009 | Microsoft Windows XP Professional With...
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
ASUS Z91N Barebone Logo
94 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
