Question about Samsung RM255LASH Side by Side Refrigerator
Samsung french door fridge not working?
We just got a samsung RF267AA frige this morning and it is plugged in, the control panel is lit up and responsive, but it does not seem to be getting cold, I hear no motor running or any noise at all.
On the control panel where the temperature is supposed to be, it only says "OF".
What is going on? What can I do?
  • 1 more comment
  • kilo999999 Dec 26, 2007
    Samsung fridge is not working. Over last 02 months 06 engineers visited and changed many parts, but still not working. Planning to go to consumer court(under warranty).
  • Anonymous Mar 31, 2008
    I HAVE A SAME PROBLEM... hELP
  • Sue Schwichtenberg
    Sue Schwichtenberg Mar 26, 2017
    Post from snowbrr on Oct 14, 2007 worked for me! 2017
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Posted on Jun 28, 2008
The power went off. When it came back on, our Samsung RFG297AA French door refrigerator cannot be reset. The manual instructions do not work. The Contol panel just shows 8's where the Fridgeand Freezer teperature is set. What do we do?
Posted on Mar 11, 2011
I have a new french door first sent back after one month at 38 temp it froze every thing this was on fridge temp. now one week later my second one is freezing where it seems too warm at 40 any answers
Posted on Mar 02, 2008
The OF indicates that it is demo mode. Check the manual for how to change modes.
I think you press the Fridge button and the Power Cool buttons at the same time for about five seconds. It should make a sound and then display the temperature instead of OF.
Posted on Feb 03, 2008
I installed one of the same models on monday.  Set the temperatures, and waited.  It came down to temperature in a few hours, and has been working fine sincve.  Have you tried changing the temperature settings?
Posted on Oct 19, 2007
I have no picture or sound when I turned on my Samsung LN40B tv this morning.
It sounds to be a main board fault. Before confirmation, contact any service technician.
Nov 27, 2013 | Samsung LN Televison & Video
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
For the first time since i bought my 37 inch 2
nadine2433, First thing to do is check your warranty status! Next thing will be research web for other owner's of same model or the 32' size for similar complaints. Try to find out the "root cause of failure" and see if something seems to "match-up" with your symptom. Yes, your cold-cathode-fluorescent-lamp back-lit lcd tv/monitor is no different than any other brand in it's basic design/operation than any other brand. Yes, plasma types are a little different, but not much. If problem gets worse and happens more frequently, the units internal "switch-mode-power-supply / ccfl inverter supply" would be first place I would investigate for a "thermally intermittant" (cold, frosty looking) solder joint on a active or passive electronic component where it is soldered to the printed circuit board. Nadine, your unit not much different than large screen computer monitor w/speakers, Just has a TV tuner circuit added to it and has remote control!!!! If this response was of some help please rate it on fixya. Do some reading in my fixya profile even though it deals mostly with black or blank n black ccfl back-lit monitors. There are hundreds of excellent ccfl back-lit monitor tech's here on fixya. 12fixlouie
Apr 19, 2010 | Samsung LN32A550 32 in. LCD TV
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung rb1955sh
if you hold the two top buttons on the right and left side of the display for 4 to 5 seconds it will reset the control board and it should restart, if not check the door switch for a bad connection. I had the same problem and i cleaned the contacts on that switch and reset the controller and no problems since. (2 months and counting!)
Dec 20, 2008 | Samsung RB1955VQ Bottom Freezer...
No picture, sound, or response from button on a Samsung DLP TV
Same Same Here - SAMSUNG SUCKS!!! One day we lazy Americans will learn not to outsource so much and get back to good ole American Made.
May 28, 2008 | Televison & Video
Control panel inactive
Your refrigerator is in demo mode. Review your manual on how to remove it.
Feb 24, 2008 | Samsung RM255LASH Side by Side...
See if you accidentally unpluged or damaged any wires under the refer during the move. There are connectors that can sometimes easily pull apart if a dolly hits them.
Dec 17, 2006 | Samsung SRS20DTD Side by Side Refrigerator
Samsung RM255LASH Side by Side Refrigerator Logo
2,219 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
