Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
Hi Gents - hope you can help. The door of my Hotpoint BF1620 won't shut. Funnily enough though it does still wash! Is it easy to replace the catch or will I need to pay an expensive engineer to fix it for me?
  • 460 Answers
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
Posted on May 15, 2009
BF1620. Why won't it heat?
Check either the pcb or possibly wiring loom behind door panel
Oct 02, 2015 | Hotpoint Dishwashers
My hotpoint diswasher is showing F as a fault in the door
can you send more information please like make model brand serial number
Sep 02, 2014 | Hotpoint 24 in. BF72 Built-in Dishwasher
Hotpoint freezer door won't shut properly, why is
make sure the unit is level side to side and front to back
Mar 22, 2012 | Hotpoint Freezers
Hotpoint wm64s indicating door not shut program will not function cus door light flashing...however door iis shut n wont open
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
All should be OK going forward
Jul 04, 2011 | Hotpoint WMA64 Front Load Washer
Replace a door on a hotpoint washing machine
http://www.espares.co.uk/advice/washing-machines/a/7/1296/how-to-fix-a-broken-washing-machine-door-hing.html
Hi go to the above espares page where you will find a video on how to replace a door hinge, should show you enough to enable you to replace the door. There are other videos on how to replace the door interlock and release mechanisms as well.
Hope this helps, if it does please remember to rate me
May 04, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
New Integral Hotpoint dishwasher LFT04
We finally worked out what all the separate parts were for!! The instructions given were hopeless! Would be pleased to help anyone who encounters the same problem.
Dec 26, 2008 | Hotpoint 24 in. BF72 Built-in Dishwasher
BF1620 leaking dishwasher leaking help.
hi,Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Aug 06, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Hotpoint first edition
UNPLUG THE APPLIANCE - Hi sorry about the delay - the door needs to lock before anything will work - So - Either the door lock is faulty or the circuitry to the door is faulty.
The door lock is not too difficult to replace. Engineers reach it by going through the front ( where the door seal connects onto the front panel)
The lock connects directly to the Timer/circuit board so if it is not the lock it will be the timer board.
Hope this helps
Mar 16, 2008 | Hotpoint First Edition WMA20 Front Load...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
963 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
