Question about Sharp Flat Panel Televisions
My lcd tv started smoking now it wont power up.
The resistor D19 i've had to replace also i had to replace D18 fuse please can you help me fix the problem.
thank you carl davies.
  • 61 Answers
SOURCE: HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
Posted on May 15, 2008
SOURCE: Element LCD tv with no power. I replaced fuse,
You probably need a new power source. Take it to you repair shop. That's what I had to do and it was relatively inexpensive.
Posted on Mar 23, 2009
  • 975 Answers
SOURCE: my tv won`t go on, maybe a fuse blew [if it has
YOU MIGHT BE ABLE TO FIX IT YOURSELF if your handy with tools , if not then to a tv repair shop , hope it helps ,AJ
Posted on Nov 19, 2009
  • 5 Answers
SOURCE: i have a gv47l fhdtv10a lcd. it made a loud pop
Thanks for the suggestions. I had same symptoms and it turned out to be fuse f3 on the mainboard, this fuse is on the top right near fuse f1.
Posted on May 23, 2010
  • 8909 Answers
SOURCE: 40" tevion lcd tv. modek no lcd 4040.wont come out
It should be fixeable. Does it do anything now?
I would blanket change them all.
Posted on Feb 18, 2011
  • 3459 Answers
SOURCE: Samsung LN406 1F 40inch 1080p
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 18, 2011
0 characters
1 Points
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
Oct 05, 2013 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Power supply card PLHL-T722A, 2300KEG033A-F, had a blown fuse F101 (T1AH250VP). Replaced fuse with T1AL250V. Plugged tv into wall, and resistor R5 lit up and started smoking. Thus pulled plug out...
We sell a repair kit for this board, which has the fuse, resistor and the IC that usually fails along with them.
You can find it at .
I've seen that board fail in at least three different ways, though, and this is the least bothersome of them.
We offer a repair service and have about 90% success even with burned boards. You don't pay any service fees if we can't fix the board.
Finally, when available we also sell boards ready for use with a trade-in option. That ends up a little more costly than a repair, though.
Sep 03, 2013 | Philips 47PFL3603D LCD TV
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I replaced an apparent blown fuse, TV still won't power on.
Most likely your power supply is damaged and will need to be replaced. Sometimes, power supply manufacturers add additional "fusible resistors" to provide additional protection.
Jan 05, 2013 | Magnavox 19MF330BF7 19 in LCD TV
My Telefunken 42" Full HD
The problem might be on your power supply.
1. Check the power supply it is located on where the plug is connected on the main board.
2. Use a multimeter it must be on AC function, to check the AC supply
sometimes the problem is just on the plug
3. Then if there is an AC supply on your plug then check the power supply
4. Check for busted fuse (usually has no reading on multimeter on diode test)
replace same type of fuse.
5. If the fuse are good check for open resistor or shorted transistors.
always replace same rating of resistor and transistors (same on number and type)
IF the problem still exist just contact me.
Hope this may help you..
Aug 20, 2011 | Flat Panel Televisions
The TV doesn't power on. I've changed the fuse and when mains power is switched on the TV makes a noise as though power is getting through. Pressing the standby on the remote has no effect -...
The problem might be on your power supply section.
1. Check for open resistor or maybe a shorted transistor. Use a multimeter
2. Also check for a leak capacitor
Is the fuse you replace is still o.k? at times the blown fuse indicates that there is a short circuit on your t.v. Maybe the noise you hear is also because of a short circuit. Be careful in replacing fuse, always replace same type for the protection of you t.v
I have a sharp lc-19dv27ut tv that is 110 volt. My daughter plugged it into a 220 plug (with the adapter on the end of the power supply cord) but without the voltage converter. She said nothing happened...
Sometimes replacing the fuse alone fix the problem,you can buy it at your local electronics supply,it is cheaper than the next parts i'm going to explain.However if you replaced the fuse and nothing happen then you might have an open fusible resistor. This resistor is lined with b+ to the voltage regulator. If open then you have to replaced them both together with the voltage regulator.
Thanks for using fixya.
Jan 23, 2011 | Sharp LC19DV27UT 18.5 in. LCD TV/DVD Combo
My lcd tv does not start though i switched on the button. pl help
Problem :
Tv wont turn on
Undo the back, check in the power supply area any blow fuse or bad capacitor.
be careful when and replace with the exact replacement of any burned part
please rate my solution
Aug 20, 2010 | Samsung Flat Panel Televisions
There is power at the wall plug, but there is no power to TV. Does the TV have a cirrcuit braker
Most tvs have a fuse or a resistor that acts like a fuse. To find it, you will need to open up the back of the TV and remove the shielding. Then look at the boards. A fuse will be obvious (short tube of glass with silver ends); the resistor may be gone and you might see the scorch marks and smell smoke instead.
I hope this helps.
Jul 13, 2010 | Protron PLTV-32 Television
TLX-03210B blanks out, audio works, with some smoke as well
Open the cover and look for the burned componet.Usually it must be a condenser. Rarely a resistor.If it is a condenser just replace it with the similar one. Note the polarity while replacing. If it is resistor need to check the associated circuit for over load. If you not sound in electronics reffer to an expert.
Sep 11, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Flat Panel Televisions Logo
254 people viewed this question
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
