Question about Husqvarna Garden
How do I check fluid level on YTH150 Hydrostatic Transaxle?
Where are the drain and fill plugs located?
    Problem Solver:
  • 9 Answers
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
Posted on Jul 10, 2009
  • ShedThoughts Nov 01, 2013
    You can't it's a sealed unit. If you think it's slipping try fitting a new drive belt, works wonders!
  • 41 Answers
If you are checking oil level,the oil fill tube is located next to starter and the drain plug is located right underneath.Hopefully you have a briggs.
Posted on May 13, 2009
03 saturn ion check and fill transmission fluid
IF YOU HAVE THE AF23-5 TRANSAXLE OR THE VT25- E VTI. TRANSAXLE YOU NEED A SCAN TOOL TO MONITORING TRANSMISSION FLUID TEMPERATURE WHILE CHECKING TRANSMISSION FLUID TEMPERATURE.YOUR VECHICLE TRANSAXLE DONT HAVE A DIP STICK TO CHECK TRANSMISSION FLUID LEVEL.YOUR TRANSMISSION HAS A DRAIN PLUG LOCATED BOTTOM OF TRANSAXLE BELOW FORWARD OF THE RIGHT PASSENGER SIDE DRIVEAXLE FACING RIGHT SIDE OF VECHICLE.YOUR VECHICLE HAS TO BE RAISED LEVEL ON A LIFT.TO CHECK TRANSMISSION FLUID.YOUR TRANSMISSION IS A DEALERSHIP FIX.WAY TRANSMISSION SET UP DEALERSHIP HAS TO CHANGE TRANSMISSION FLUID.
Nov 12, 2012 | Cars & Trucks
1996 Honda Accord EX Manual trans. Where is oil level plug. what kind of oil?
All Honda manual transaxles use the Honda Manual Transmission Fluid (MTF) as the original factory fill. This oil is similar to a 10W-30 or 10W-40 viscosity engine oil, and this oil can be substituted temporarily. However, the manufacturer recommends the use of their MTF when changing the fluid.
Level Check
The transaxle fluid should be changed every 90,000 miles (144,000 km) or 6 years under normal driving conditions. In severe driving conditions the fluid should be changed every 30,000 miles (48,000 km) or every 2 years, whichever occurs first.
Make sure the vehicle is on a level surface. If the vehicle is raised, make sure the vehicle is safely supported and level
NOTE: Do not confuse the drain plug with the fill plug.
The fill plug is in the mid section of the transaxle. The drain plug is near the bottom of the transaxle.
  1. The oil level is checked by removing the oil fill plug on the side of the transaxle. The transaxle fluid should just meet the lower threads of the transaxle fill hole.
  2. Remove the oil level check bolt from the side of the transaxle. If oil runs out, or if oil can be felt near the threaded fill hole opening, reinstall and retighten the bolt to 33 ft. lbs. (45 Nm).
  3. If the level needs to be topped off, pour oil in slowly until it begins to run out then, install and tighten the filler bolt to 33 ft. lbs. (45 Nm).
Cheers,
"Please rate this solution or kindly leave a Testimonial"
Sep 05, 2011 | 1996 Honda Accord
Where do you put the transmission fluid?
There should be a dipstick, but some modenr transmissions are sealed and have no dipstick, and have a drain bolt instead.
LEVEL CHECK Inaccurate fluid level readings may result if the fluid is checked immediately after the vehicle has been operated under any or all of the following conditions:
  • In high ambient temperatures above 90°F (32°C).
  • At sustained high speeds.
  • In heavy city traffic during hot weather.
  • As a towing vehicle.
  • In commercial service (taxi or police use).
  • If the vehicle has been operated under these conditions, shut the engine OFF and allow the vehicle to cool for 30 minutes.
NOTE: The transaxle in your vehicle requires special procedures for checking and adding automatic transmission fluid. Fig. 1: Location of the fluid level screw and the fill/vent cap needed to check the fluid for the 4T40E automatic transaxle 87951085.gif
Fig. 2: The transaxle vent is also the transaxle fill cap 93201p22.jpg
Fig. 3: The vent cap is obstructed by the intake duct on the 3.1L engine. You will probably need to the remove the air intake duct 93201p30.jpg
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Place a container under the fluid level screw. Fig. 4: The fluid level screw (see arrow) is located above the transaxle pan on the passenger side of the vehicle 93201p42.jpg
  4. Remove the fluid level screw.
  5. Ensure the oil level is at the bottom of the level screw. NOTE: Because the transaxle operates correctly over a range of fluid levels, the fluid may or may not drain out of the screw hole after removing the screw. If the fluid drains through the screw hole the transaxle may have been overfilled. When the fluid stops draining the fluid level is correct, and you may install the level screw. If the fluid does not drain through the screw hole, the transaxle may have been low. Add fluid at the vent cap location in 1 pint ( 1?2 liter) increments until the oil level is at the bottom of the oil level hole. Use a long necked funnel to avoid spillage.
  6. Install the oil level screw and tighten to 124 inch lbs. (14 Nm).
  7. Lower the vehicle.
  8. Connect the negative battery cable.
Feb 12, 2011 | 1998 Chevrolet Malibu
Just got 1996 chevy cavalier. Where do you add transmission fluid?
the transmission fluid goes down the dip stick hole ,either use a small funnel or special tranny fluid refill top up bottle
Feb 04, 2011 | 1996 Chevrolet Cavalier
How to check trasmission fluid no dipstick just a red cap
4T40E Automatic Transaxle CAUTION
Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of the transaxle fluid to exhaust pipe. The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid.
  1. The fluid level should be checked when the transaxle is near room temperature or at 104°F (40°C). To acquire this, left the car idle for 3-5 minutes with all of the accessories off. Fig. 5: Location of the fluid level screw and the fill/vent cap needed to check the fluid for the 4T40E automatic transaxle 87951085.gif
  2. Apply the brake, then move the gear shift selector through all gear ranges, pausing three seconds in each range. Shift the lever into P.
  3. Raise and safely support the vehicle.
  4. Place a suitable drain pan under the check plug to catch any fluid that may drip out.
  5. Remove the oil check plug. The oil level should be at the bottom of the oil check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the screw hole when the screw is removed.
  6. If fluid drains through the screw hole, the transaxle may have been overfilled. When fluid stops draining, then fluid level is correct and the check plug may be installed. If fluid does not drain through the screw hole, the transaxle fluid may have been low. Add fluid at the vent cap location in 1 pint increments until the oil level is at the bottom of the oil check hole.
  7. Install the oil check plug/fluid level screw and tighten to 10 ft. lbs. (14 Nm).
  8. Carefully lower the vehicle.
Jan 21, 2011 | 1997 Pontiac Sunfire
WHERE IS THE TRANSMISSION DIPSTICK LOCATED ON A 1998 CHEVY CAVALIER? WANTED TO CHECK THE FLUID LEVEL
DONT HAVE ONE WHERE DIP STICK USE TO BE IS A RED VENT FILL CAP THATS WHERE YOU POUR TRANSMISSION FLUID. BUT THE TRANSMISSION WAS MADE FOR DEALERSHIP TO CHECK.THEY HAVE TO RAISE VECHICLE LEVEL AND ON THE TRANSAXLE HOUSING THERE IS A CHECK PLUG ITS LOCATION ITS ABOVE THE OIL PAN DRAIN PLUG.WITH VECHICLE RUNNING UP IN AIR LEVEL ON THE LIFT.THE CHECK PLUG IS REMOVED IF NO FLUID COMES OUT CHECK PLUG HOLE ADD PINT DONT OVERFILL.IF FLUID POUR TOO MUCH FLUID IN TRANSMISSION IF SLOW DRIP FLUID LEVEL CORRECT.
Oct 31, 2010 | 1998 Chevrolet Cavalier
Where is the dipstick for transmittion fluid
on these models, it is not necessary to check the fluid at regular intervals. if leaks or shifting problems lead you to suspect a low fluid level, its a sealed system. heres how to check tranny fluid. with vehicle raised and supported. start the engine , then move gear selector through all gears and back to park. with engine running and the transaxle at normal operating tempurature( having idled for 3 to 5 minutes), locate check plug on transaxle. the plug is located by the pan, across from oil drain plug. remove plug, the level should be at bottom of check hole. if fluid pours out a lot, then it is over full. also make sure car is level before starting. the fill cap is on top of transaxle, use a long neck funnel to fill if needed. the cap is usually red.<!-- from fixya rte -->
Aug 16, 2010 | 1999 Pontiac Grand Am GT
I can not locate trans.dip stick on a 1998 Olds Cutlass.
Sorry I think the 1998 cutlass has a 4t40e trans. It has no dipstick. You have to remove a plug by the passenger CV shaft and fill the trans until fluid runs from the plug.
Apr 05, 2009 | 1998 Oldsmobile Cutlass
Manual transaxle
The 'fill' plug should be on the transaxle housing behind the front passenger-side wheel and requires a 17mm socket. the 'drain' plug should be on or near the bottom in about the same area and requires a 24mm socket. To check the fluid remove the 'fill' plug (some fluid may spill out so be prepared) and ensure that the fluid level is up to the bottom of the 'fill' plug hole. (easiest way is with your finger, if it gets fluid on it when inserted, you're OK). Your service manual recommends changing this fluid every 15,000 miles according to my sources. Make sure you don't lose any washers and that the plugs are clean when put back. Your transaxle takes 4.6 pints of GL-4 (75w85 or 75w90) - don't use GL-5 as it can contain additives which can corrode your bearings, and tighten both fill & drain plugs to 22-25 lb.ft. (roughly snug then 1/8 turn) being careful not to over tighten which can damage the threads easily.
Also, 'all-wheel-drives' have a transfer case which requires the same service. The fill & drain plugs are roughly near the center, behind the exhaust manifold. Follow the same procedures and use the same fluid.
Nov 24, 2008 | 2003 Mitsubishi Lancer
Changing the transmission fluid
Once you've drained the transaxle by removing drain plug, re-install drain plug and torque to mfg. specs. To fill transaxle, you need a 5/8" square drive attached to a 9" extension, breaker bar or ratchet. Raise vehicle on hoist, or jack up and secure with jackstands. The fill plug is located above and slightly to the right of the location where the passenger side c.v. halfshaft enters the transaxle. Remove fill plug. Using a fluid exchange tool available at your local parts store, fill with automatic transmission/transaxle fluid available only from a Suzuki dealership, (part# ESSO LT 71141) until fluid starts to run out of fill hole, then replace fill plug, and torque to manufacturer specifications. I'm a former Suzuki technician. I hope this was helpful.
Aug 02, 2008 | 2007 Suzuki Forenza Sedan
Garden Logo
1,547 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
