Question about Dell OptiPlex 330 Desktop Desktop Computer
AFTER SP3 installed network printer not working
In my optiplex 330 brand new yesterday sp3 installed after that network printers not working then i restored now sp2 only but still n/w printers not working kindly help me ...my boss is angry. Thanks & Regards
  • 1 more comment
  • lion1t May 14, 2009
    others in the workgroup are able to print. i have reinstalled network printer no use.no local printers are connected to this computer.please reply.just after installing sp3 it happen..and after restoring the pc also the same problem.
    Thanks.
  • lion1t May 16, 2009
    network printers using separate ip address and connected with network cable not from printservers.it is pinging. (hp 4200, sharp AR-M236).please reply...thanks
  • lion1t May 17, 2009
    i did as you said exactly..everything goes well when printing test page..ERROR PRINTING...PLEASE REPLY.
    Thanks
  • 1,218 Answers
A printer with the NIC eliminates the need for complicated network printer configuration because it simplifies the way it is set up within the network. A network printer is not necessary in order to share a printer within a home/office network get more information and help for Network Printer Configuration .
Posted on Sep 07, 2010
  • 221 Answers
You should go into Start>Printers and Faxes, write down the exact printers that you have (including server name or IP address) and then delete them by right-clicking on each printer and removing it. Once they're gone, add them back by using the Add Printer wizard or by browsing the network to find them and re-connect them. Since you specify that the network printers aren't working, I'm guessing that local (USB, parallel) printers still work properly. This would rule out the local print spooler, and since you didn't mention that everyone else can't print, it's probably not the print server either.
Posted on May 13, 2009
  • 1 more comment
  • Sphynkter
    Sphynkter May 14, 2009
    are the network printers attached to a WIndows print server or are the network printers using IP print servers (like a Jetdirect) or something? What model printers are we dealing with? Can you ping the IP addresses of the printers directly from your machine?
  • Sphynkter
    Sphynkter May 16, 2009
    Try setting up a new network printer on your machine from scratch. To do this, go to Start, Printers and Faxes, and then find the Add a printer wizard. You'll need to add the new printer using the wizard. Be sure to specify the correct TCP/IP port (this should correspond with the IP of the printer you're trying to use). When prompted for the type of printer or driver, click "Have disk". This will bring up a new window with choices of manufacturers and models of printers. Locate HP in the manufacturer's list, and find the HP Laserjet 4000 in the model list and select OK. When you finish with the wizard, it'll ask you to print a test page, click yes. A test page should print out. Let me know if this works for the HP Laserjet 4200 printer. If you have any trouble or questions, let me know.
  • Sphynkter
    Sphynkter May 17, 2009
    Please click on Start, Run, and type in "services.msc". In the window that pops up, look for the "Print Spooler" service Name list and tell me if it's started or not, and what the Startup Type is. If things are normal, the Print Spooler service should be set to Automtaic start, and should be started all the time. If it's not started, right-click and start the service. Then try printing again. Let me know what happens.
4 Suggested Answers
EricDaniels
  • 80 Answers
SOURCE: No Ethernet controller on Optiplex XP Pro SP3
Hey evolution200.
Heres the installer file for your Broadcom Ethernet Controller:
ftp://ftp.us.dell.com/network/R132254.EXE
Get back to me and let me know if that worked out for you.
Posted on Feb 03, 2009
  • 174 Answers
SOURCE: pixel shader error 06 on my optiplex 330
Graphics Card
Minimum Requirement
VRAM (256 MB)
DirectX 9.0c / Shader 3.0
NVIDIA GeForce 6800 series
ATI Radeon HD 2400 Pro
Your Dell has an Intel GMA 3000 onboard with up to 256 MB shared memory and isn't listed so probably isn't supported.
Posted on Mar 18, 2010
kurtis_1318
  • 382 Answers
SOURCE: i need audio driver on
Click Here and on that web page, click on the blue download button as shown below.
Posted on Feb 16, 2011
I need audio driver on windows xp sp3 for dell optiplex 330
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Canon clc 1100 series printer requires login and password but not
Go to the driver properties and check device settings tab to see if job accounting is enabled. Un-check if not used.
Jun 16, 2010 | Canon Office Equipment & Supplies
Apssearchinterface not found
CAUSE
Windows XP SP3 introduces a new .dll file that is named Wlanapi.dll. This file is installed in the %WINDIR%\System32 folder. Certain device driver installations for some third-party wireless network adapters also install a Wlanapi.dll file in the %WINDIR%\System32 folder. If such a file is installed in this folder before you install Windows XP SP3, the Wlanapi.dll file that is associated with the network adapter is replaced by the file from the Windows XP SP3 installation.
RESOLUTION
To resolve this issue, check the Web site of the wireless network adapter's manufacturer for the latest device drivers that are available for a Windows XP SP3-based system. Then, download and install the latest device drivers for the wireless network adapter. Source(s): http://support.microsoft.com/kb/950720
Jul 07, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Driver problem
Some drivers doesnt works with xp sp3, try uninstalling xp sp3 from add and remove programmes.
Jun 17, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Cannot print to Xerox WorkCentre M128 after upgrading XP to SP3
plz tell us how i can remove spanner in my copyer toshiba 2050
Jun 16, 2009 | Xerox WorkCentre M128 Copier
Cannot install in win XP
dear frn, that is the problem of win XP sp3, so better to use the winxp sp2 and better to update it. instead of using sp3 ok
May 09, 2009 | Samsung SCX-4300 Monochrome Laser...
Hey evolution200.
Feb 03, 2009 | Dell OptiPlex GX280 PC Desktop
Hp 3055 and sp3
There are 2 ways you can remove it. The easiest is to go to Start>All Programs>Accessories>System Tools>System Restore. Make sure Restore my computer to an earlier time radio button is selected and click Next. Bold calendar dates indicate available restore points. Choose the date that you installed SP3 and time if it has more than one, click Next and it will restore it to the way things were prior to the update.
Alternatively, Start>Control Panel>Add or Remove Programs and scroll down to Windows XP Service Pack 3 and highlight it then click Remove on the right. I prefer System Restore but that's me.
If you feel this helped you, please help me out and rate the solution accordingly. Thanks for using fixya.com!
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Driver will not install due to "unknown error."
I am wondering if you have uninstalled all previous drivers .. I know in some instances the Alps Yahoo Groups suggest you un-install all drivers, so the program looks at it as a brand new install driver.
Try this.
Dec 01, 2008 | Alps MD 1000 Thermal Printer
Dell OptiPlex 330 Desktop Desktop Computer  Logo
119 people viewed this question
Alun Cox
