Question about Kodak EASYSHARE M763 Digital Camera
Kodak M763 - Battery Indicator
Hi
I have Kodak M763 camera. How can I check if the battery is fully charged?
There is one battery indicator which appears at the time of low battery, but I also want to check the status on whether the battery is fully recharged... or almost full... like that. Please help.
Thanks
Sri
  • 188 Answers
SOURCE: Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Posted on Jul 02, 2006
SOURCE: red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Posted on May 27, 2009
BillB-SA
  • 2761 Answers
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Oct 31, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Kodak M763 camera won't turn on.
If the camera has recently been dropped you may have lens damage which is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 04, 2009
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
I have a kodak m763 and it will not turn on or charge what's the problem?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 12, 2011 | Kodak EASYSHARE M763 Digital Camera
Camera wont turn on-batteries are OK
Here are the steps for M763 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak EASYSHARE M763 Digital Camera
My kodak M763 lense is sutck and the camera wont turn on
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 12, 2010 | Kodak EASYSHARE M763 Digital Camera
When i try to trun on my camera it will blink on then go right back off.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EASYSHARE M763 Digital Camera
Can't get the camera to turn on.
It sounds like a repair, therefor I have attached the KODAK contact at the end of the this solution. But before you call, here are a few steps you can try, I hope it will work.
Dec 07, 2009 | Kodak Easyshare M753 Digital Camera
My kodak m763 lens wont open. and when i turn on the camera it says kodak easyshare and it turn back of
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
Nov 30, 2009 | Kodak EASYSHARE M763 Digital Camera
My Kodak Easyshare M7623 Digital camera will not come on. It is completely charged and the lens is out. When i push the ON/OFF button the screen comes on and quickly goes of. The lens remains out the...
Here are the steps:
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 20, 2009 | Kodak EASYSHARE M763 Digital Camera
I have a Kodak M763. The camara don't want to turn on. Don't work
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Kodak EASYSHARE M763 Digital Camera
I just want to know what battery to buy for a Kodak M763 Easy share digital camera
This is the battery that you need to buy its a Kodak KLIC-7001 Lithium-Ion
Apr 24, 2009 | Cameras
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak EASYSHARE M763 Digital Camera Logo
122 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
