TV Receivers and DVRs
Problem for TV Receivers and DVRs
Generic problem for all TV Receivers and DVRs
Archos DVR station
By heathers on Oct 14, 2007
According to manual the station should be pass through however if I remove device the signal from Sat box does not reach the tv.  station is powered and cables as diagram
Can you advise
Same Problem
Mar 22, 2008
-   trying to connect Archos DVR station and following the instructions BUT the satellite system wont work when we do this!! Any ideas? Mo-   Guest
Solution #1
posted on Oct 15, 2007
Not Rated)
Shuttle83
Rank: Guru
Rating: 85%, 982 votes
Hello heathers,
The term pass through does not necessarily mean passive. What you could have is a switched pass through system. which basically means as long a power is on the signal is not acted upon by the device hence the signal passes through the box when the power is switched off the box stops passing the signal. if you want the signal to from the Sat box to the TV and bypass the DVR you could use a switch to do that (this is just a suggestion).
I hope this helps,
Shuttle83
Was this helpful?
Yes
No
Popular Solutions for TV Receivers and DVRs
Questions and Unsolved Problems for TV Receivers and DVRs
Answer
how can I use my westell 327W modem as a wireless router? It came with a USB wireless card inside a... (More)
Answer
what is the dock for on the front of the tv
Answer
Power went off when it came back on, unable to turn on or reset Motorol CATV CONVERTER BOX dct 2224
Answer
Hi I installed the older version of the pctv hd pro stick 801e. It worked fine, but I unplugged the... (More)
Answer
i have no idea what my reciever code is for my sagem freeview and need it to access certain settings... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For TV Receivers and DVRs:
Top TV Receiver and DVR Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Receiver and DVR Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
