Question about Yamaha RX-V2700 Receiver
Receiver will not connect to Home Network.
I recently had to replace  my home network Linksys Router with a new Linksys Router with 4 port switch.  The Yahmaha is set up with DHCP on and will easily connect to the internet for net radio however, it will not see my shared MP3 music folder on the PC, it previously had.  Now what I found was in the firm ware on the router I needed  to go to UPnP and under the HTTP I had to change it from 192.168.1.0 to 192.168.1.101.  Everytime I then shut the Yamaha receiver off then restart it still won't find my network.  As long as I go put that port back to 192.168.1.0 then back to 192.168.1.101 it finds the newtork.  Anyidea how to make the receiver keep finding my network?
Thanks Wade
Which software i should install on my pc to play audio files stored on my pc through yamaha rx v2700
Posted on Mar 28, 2008
Need driver and firmware for LinkSys RTP 300, or how to set it up for simple home network with interneton the PC and laptop as the 2nd computer.
No drivers are required since there is no actual installation to to the computer. Connect the ISP modem to to the main LAN network port. Then use any available port to access network. 1.Power 2.Main drop. 3.Network. That's it!
If the router is used, you may want to reset custom settings by, holding in the reset pin till it cycles.
Advance setup.
http://www.cisco.com/en/US/docs/routers/csbr/rtp300/installation/guide/RTP300_UG.pdf
Oct 16, 2012 | Linksys Rtp 300 Broadband Ethernet Voip...
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
Have linksys broadband router model # rtp300, formally used to receive Vonage service. Can this devise be used to connect a second computer in my home?
Yes.
This is a wired router.
you can connect second computer to the router.
You will need to connect the cable to the router's ethernet port and computer.
Click Here to know more about router and network
Feb 04, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Central home network
(add small 4 port hub) from cable router out to hub port 1.-take cat5 from central insert in port 2 of hub.- insert cat5 in port 3 of hub then other end in now open cat5 port
Jan 03, 2010 | CommScope 1000 FT RG6 QUAD/CAT - 5E 4 -...
Home Computer Network Confusion
it easy plug your big plug rg 45 cable from the 2010 into your port 1 on your router then buy more rg45 cable from comp store plug it into port 2 then into comp 1 plug another one into port 3 on your router and plug it into other comp. everything should work xp will pick up and install anything needed. have fun surfing
Sep 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
OK to mix and match? Have Linksys router and a Belkin wireless G mimo ... Not sure how to hook any of it up?
How many computers/printers/etc are you trying to put on the network? If this is a home network, it's probably unnecessary to have 2 routers. Also, if you're only using the wireless router for laptops to connect to wirelessly, you should consider dropping the Linksys out of the network completely. On how to hook the two together, though, it really depends on what you're trying to do.
Sep 01, 2009 | Linksys Wireless Ap + 4 Port Router...
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Network key
Lkrawlings:
Can you go into your router from IE? like http://192.168.x.x, then from this configuration page of your router you can find what key you had put into your router. Make sure the type of security you are using like WEP, WPA, PSK, WPA2 etc. This key should match on your desktop or laptop machine to gain connection to your router.
If you are unable to find your key like this then:
You could refresh your router to factory defaults by pressing for 5 seconds, you will find this hole at the back of your router. try going again into your router like I said above and make up any other key.
Hope that helped!
Dec 07, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Help setting up hwr54g as an access point
Yes there is an easier way! Just setup the router as you would any normal setup. Follow the directions to set it up for the first time. What you want to do is have the put in all of your information that you need for it to communicate with your Modem. This will automatically place the router onto your network. Now the part that I believe you want is for this to be secure! Well setup either a WEP or WPA these are both encryption Protocols that will denie access to anyone other than you or someone you allow to access your network wirelessly.
You do not really have to go through all of the trouble of setting up specifics. As long as the two devices communicate the router and the modem will do the rest. I do this everyday in my daily work day! Anymore quesitons please feel free to ask!
Nov 27, 2007 | Hawking Wireless-G HWR54G (603992506064)...
Yamaha RX-V2700 Receiver Logo
439 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
