Question about Kenmore Washing Machines
Kenmore elite top load washer 11020992992 wont agitate or spin
Our washer wont agitate or spin. It will fill with water and it drains water.
jsrock516
  • 5911 Answers
SOURCE: Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Posted on Aug 04, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Posted on Apr 26, 2009
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
My spin cycle will not work
replace coupler, you have to remove case
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Washing Machines Logo
87 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
