Question about Echo Garden
Engine won't accelerate on Echo PE269 edger
I have a Echo PE 260. When I give throttle it boggs down like its starving for air but no acceleration. can you help me? I've cleaned the exhaust port and replaced fuel filter and plug.
  • 246 Answers
Hello rbronniman:
I Understand you have Cleaned the Exhaust Port, but Did you try Running the Engine with the Muffler Off the Unit?
Sometimes the Muffler or Spark Arrestor Screen can be Restricted Also.
If the Muffler and Spark Arrestor are Clear, then the Problem is Either Worn Rings, Bad Carburetor Mount Gasket, Improper Spark Plug Gap, the Carburetor Metering Jet is Not Operating Correctly or the Internal Carburetor Filter/Screen is Restricted and Requires Cleaning/Replacing.
To Correct this you need to Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Jet Diaphram Dowl should Just be Touching the Metering Jet Actuator.
>>The Metering Jet is Under the Carburetor Plate with 4 Small Screws Holding the Cover Plate to the Carburetor Body.
>>Check the Internal Screen Filter for Restriction also.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
Echo PE-2601 gas edger gets hot and shuts off, then after cool down starts back up
sounds like the spark plug is breaking down at hot temps. replace it. if that dont work the coil is going bad
Mar 19, 2015 | Echo Pe-2601
Why does my ATV bog down and die when I keep the throttle wide open?
If you are lucky, you might just need new fuel filter and the fuel bowl cleaned out, and maybe new air filter. If not so lucky you need carburetor rebuilt. Backfire is usaully caused by engine running too lean ( too much air for the amount of fuel present). Fuel bowls get gunk in them and the fuel needles and fuel jets get varnished up. The accelerator pump gets worn out gaskets and/or bellows and doesn't give the right amount of fuel mist when you accelerate.
Full Choke is indicative of a motor starved for fuel
Mar 04, 2015 | ATVs
Why does my 1995 Sonoma 4.3 bogg down when I give it gas or passing gear?
Depending on the mileage, the most common problems are low fuel volume due to a restricted fuel filter or weak fuel pump. The other possible cause is a partially clogged catalytic converter, which puts back pressure on or "boggs" the engine when trying to accelerate.
Mar 03, 2015 | 1995 GMC Sonoma
I have an Echo Edger PE 200. The edger will not idle.
hi rgiles_5050
Adjust your idle speed with the idle screw located on the carb...if that does not solve your problem then take your carb off and clean it again because you have some debris/dirt in the low speed circuit, this time make sure to blow all the jet holes out with compressed air to blow out any wedged in dirt
Please take time to rate me
Bud
Oct 14, 2012 | Echo Pe-200 Lawn Edgers
1988 cutlass ciera boggs down when i accelerate
Hello! You have symptoms that point to incorrect fuel pressure.
First have the fuel pressure tested as follows; #1...engine running at idle: 13- 20 psi. #2...key on engine off: 23-30 psi. If pressure is incorrect change the fuel pump.
Does the engine "surge" at idle? If so, check the "fuel injection pressure regulator idle air control valve". Apply a vacuum to it; If fuel flows it is not the problem.
Guru.............saailer
Dec 13, 2009 | 1988 Oldsmobile Cutlass Ciera
Goes bad when you give it trottle
If your bike boggs down when you attempt to accelerate, it usually indicates that it is starving for fuel. It could be many things..an inline filter, trash in a jet, a stopped up strainer in the gas tank, excessive plaque in the carb. You can try some simple fixes such as replacing an inline filter, (if you have one). But usually the fix will involve removing the carb and soaking it in carb cleaner, replacing seals, gaskets, blowing out the jets, cleaning or replacing the lines. If your bike idles ok, but when you throttle up it boggs, you are getting enough fuel to make it idle, but not enough to accelerate, so when you call for more fuel, (accelerate), and it can't get it, the mixture leans out, (has too much air and not enough fuel). Hopw this is helpful. Good Luck!
Oct 23, 2009 | Honda XL 125 R Motorcycles
Open Questions:
Garden Logo
1,250 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
