Question about Acer Aspire 3100-1405 Notebook
Mouse and keyboard freeze.
On start up mouse and key board lock up will start to boot but cant access anything so cant update drivers could it be hard ware fault. thanks
  • Acer Master
  • 13,433 Answers
Its a very common hardware fault with these laptops, can you open setup or bios? that is opened right when the power is turned on the and screen says press F2 to enter bios or setup, if you can't enter bios then you have a faulty motherboard, usb ports don't work either? (usb keyboard and mouse don't work?)
Posted on May 13, 2009
  • 20 Answers
HI , how are u, it is a hardware problem and it have a problem in motheboard. so u can repair ur laptop motherboard.
MY DELL E520 FREEZES AFTER START UP
Is this a recent occurance? Try a System restore. Have you done ANY Driver updates? Any updates at all? Added any hardware? When you boot to safe mode it only loads minimal drivers.
Jan 28, 2013 | Dell Dimension E520 PC Desktop
Lenovo R60 freezes and no response from mouse or keyboard
1) try to RESTORE to some point where the computer was working.
2) Update the BIOS +CHIPSET and RUN it.
2a) see if working. If NOT working go the step #3
3) update the USB driver from the supplier company.
4) updae the driver for keyboard +mouse , uninstall and reinstall.
God bless you
Oct 18, 2012 | IBM Lenovo ThinkPad R60 Notebook
Accidently uninstalled softtware for the mouse and now have no mouse to access anything. What are my options and how do I get the mouse backé
Switch on the computer and use the keyboard as they did in the pre-mouse days
ie tab key to move around the screen and arrow navigation buttons
Or go out and buy a really cheap USB mouse plug it in and then go get the drivers from the GE website
Nov 20, 2009 | GE Wireless Optical Mouse
Keyboerd failer when starting
try to change the mouse or keyboard from serial connection to usb, or likewise, might be both of them are conflicting..if both are usb...also update the drivers, try it.,,
Nov 10, 2009 | Dell Dimension 2400 PC Desktop
Just bought Acer laptop (series 5517) and the keyboard appears to be locked. How do I unlock it??? Please help 9/27/09. Thanks!
DOES THE MOUSE WORK OK?
If not, re-boot and press the [F8] key to get into the "Safe Mode" screen. See if the keyboard works in Safe Mode.
If so, go tothe Control Panel and select "keyboard" and update the drivers.
If not, then re-boot and select the [F8} key again, but choose "Start computer in last known good configuration"
If it still doesn't work, but the mouse does, then the keyboard is disconnected or the connector is loose; open 'er up and connect it.
Sep 28, 2009 | Acer 91.63X07.001 Keyboard
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Locked keyboard and mousepad on acer aspire 6920G
Almost same problem: the mouse froze.
Found a nice solution at another website: switch off the pc, unplug the power supply cable AND remove battery. Press "on" switch for 20 seconds. Now re-install battery, plug back power supply cable, and switch on. Worked for me (what exactly worked for me I don't know but hey)
Good luck.
Oct 20, 2008 | Acer Aspire 5100 Notebook
Hello! I have an Acer Aspire 3000 laptop, with a really weird problem. the in-built keyboard and mouse-pad won't work.... sent it off to the computer shop and they said it was a software problem and that...
welcome to fixya
use you external keyboard and mouse and try to goto device manger and find the hardware keyboard and mouse and try to update the drivers this could be the problem ....
you can also check in the search bar try typing in keyboard the search menu in start menu this should have a Standard PS /2 keyboard or something like that if not then the drivers are missing needs updateing
hope this helps you out if not plz let me know
have a good day
Aug 05, 2008 | Computers & Internet
Keyboard/Mouse Freezes System Sporadically
Wireless routers generally are 2.4 Ghz, as well as the wireless keyboard and mouse. I think there is interference from the router that causes the keyboard and mouse to hang. I had the same problem with my 2.4 Ghz cordless telephones and my new wireless router. Went to 5.8 Ghz telephone and the problem stopped. I'm not sure yet how to work around the keyboard/mouse issue.
Sep 17, 2007 | Computers & Internet
Acer Aspire 3100-1405 Notebook Logo
290 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
