Question about Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle
1978 Shovelhead has a miss or backfires through the carb at slower speeds. Runs fine over 50 mph. Changed intake O ring gaskets, still pops and misses at slower speeds.
  • kschorr Jun 22, 2009
    It had the first edition electronic ignition but was upgraded with a Craine System
  • bluesdude007 May 11, 2010
    Does it have points or has it been converted to electronic ignition?
  • 23 Answers
Make sure your hotwire to the coil is making a good connection. Check air intake manifold for air leak - o-rings can be tricky to get installed correctly. Finally, change carburator jet to richer mixture. Popping backk through the carb means lean fuel mixture.
Posted on Aug 17, 2009
MOTORCYCLE will not go over 50 mph or it bogs
iIf it is not fuel system, not fuel / air balance might be ignition system or wear and tear in the engine itself. Assuming the brakes are set up correctly and not dragging. Is the ignition timing correct. Is the compression okay? Cylinder head condition. spark leads good? Sounds like a trained mechanic with some diagnostic equipment might help you track the problem down.
Good Luck with it
May 30, 2015 | 2000 Suzuki VZ 800 Marauder
Popping from pipes and carb
Hi Tommy, popping, coughing, spitting, or backfiring through the carburator or induction module can be caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 18, 2012 | Harley Davidson XLH 1000 Sportster...
Have a miss firer, pops back in the intake. changed spark plugs the coils cam sensor intake gaskets no fix
backfiring through the intake is usually a sign of a lean condition i would check the fuel pressure.
Apr 27, 2011 | 2005 Ford Escape
Backfires on deceleration and also is getting black above shift side carb.
A lot of backfiring on deceleration is related to reused or leaking exhaust gaskets in the head . The gaskets are leaking air into the exhaust. If you are experiencing carbon on the intake side , I would recommend replacing the intake o-rings and gaskets, spark plugs, and spark plug caps. These can all be related to backfiring through the carburetors.
Aug 24, 2010 | 2005 Yamaha V Star 1100 Classic
I have a 79 shovelhead i had been having trouble with plugs fouling out and it was acting like it wasn't getting gas and started backfiring i think i got the plug part fixed but now it backfires when i...
Sounds like you have an intake leak. You can start the bike and spray the intake where it meets the heads with WD40. If you find any variation in the idle of the bike you have an intake leak and must change the seals. Be carefull to not spray the WD40 int the carb because this will alter the idle and give a false reading
Jul 09, 2009 | Harley Davidson FLHTC - FLHTCI Electra...
1981 Wide Glide Bike is missing and backfiring
open up the ignition cover plate and check the backing plate. it may have come loose and threw the bike out of time.
make sure your plug wires are plugged on tight and the coil wires are secure.
It is most definitely a timing problem.
Jun 05, 2009 | Harley Davidson FXDWG Dyna Wide Glide...
Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle Logo
1,096 people viewed this question
Top Harley Davidson Toys Experts
ray gallant
Mark McGinty
Mark McGinty
Charles Ma
Charles Ma
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
