Question about Olympia OL2410 Cordless Phone
Hi!  My phone does ring, but when i try to pick up the call the display says "Out of Service".  This is weird considering that the phone has been working for about a week now but as of yesterday it wasn't working properly.  Please help.  Thanks!
0 characters
1 Points
Ansering service picks up after 2 rings
There is a control on the phone that you can set for a different number of rings before it picks up. Check the manual for location and operation.
Aug 19, 2015 | Phones
GE 25861GE3B
Good day Mickey, First I'll provide you with a link to the manual if you need it: I know it's a weird lokking link, it's a server from thompson which is the parent company for GE home electronics, not exactly yoo east to find. Anyway on to the problem at hand, To make it answer after more rings there is switch on the back of the base. It hase 3 settings 3/5/TS. If set to 3 it will pick up in rings, set it to 5 and it will pick up in 5 rings. The TS setting stands for TollSaver, do not use this setting, TS will cause it to pick up in 2 rings. Set it to 5, however if you want to get 10rings before it picks up there's a little trick. When the answering machine gets full it will start picking up in 10rings, they do this so you know your answering machine is full. You can still leave a meassge even when it's full, it will automatically delete the oldest message to make room for a new one. However the display on the machin will display an F instead of the number of new messages. Well I hope the helps with that problem, because I hate to be the bearer of bad news but that phone has a maximum capability of 10 speed dials (0-9) and that's the max. There are models on the market with lots of speed dials but there usually corded phones. Well Good Luck & I hope this helps. L8R
Sep 16, 2007 | Uniden Cordless Phone
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Phones
My answering service picks up after 3 do i extend the answer time to 6 rings or so?? I have the 9417 CW
Ask your provider to change your voicemail to pick up in36 seconds instead of 18. Each ring is 6 seconds. Hope this helps
Sep 24, 2011 | Aastra Telecom Aastra 9417 CW Corded Phone
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Jul 24, 2011 | Uniden Cordless Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Phones
Can't call out and Phone keeps ringing on in coming calls
It was all in the outside phone lines. But thanks for the intrest.
Dec 29, 2008 | Panasonic KX-TG1034S Phone
Ring Cycle
On page 20 of the manual it tells you how to change from TOLL SAVER default to 2-7 rings.
If you need a manual try this one
Sep 23, 2008 | Panasonic KX TC1503 Cordless Phone
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
Olympia OL2410 Cordless Phone Logo
21 people viewed this question
Top Olympia Phones Experts
Are you an Olympia Phone Expert? Answer questions, earn points and help others
