Question about Jacuzzi Cyget In Ground Pool Pumps
Tryomg to locate the owners maual or technical specs, just moved into a house with aboveground pool and no maual with the pump Jacuzzi 15-LRC-5-48-S/B pump
Looking for the operating manual for the Jacuzzi 15-LRC-5-48-S/B pump
  • 17 Answers
SOURCE: jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
Posted on Jun 25, 2009
  • 177 Answers
SOURCE: air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Posted on Aug 03, 2009
  • 366 Answers
SOURCE: jacuzzi at higher elevation to swimming pool,
you probably have a check valve (back flow preventer) on the line that supplies water to the spa when the pool is filtering as normal. Your check valve may have some debris in it or the seal inside may have failed allowing the water to drain into the pool when the system is off. You should see a valve on the return line that splits off from the pool return line on your system. There are several different check valves on the market, some have a clear lid that you can inspect without taking it apart. Some of them cannot be taken apart. Your challenge will be to find the check valve, then try to check to see it debris may be holding it partly open or it the rubber seal inside is damaged or missing. I hope this helps.
Posted on Sep 24, 2009
  • 8404 Answers
SOURCE: 15 by 48 pool i upgraded the filter too the 2500
Get replacement ports of the proper size from your pool supply house. Dont use adapters as this constitutes a restriction and will lead to troubles. If you cannot find the correct diameter - I suggest you add a second suction and a second discharge of the size you can get and pipe them together outside the pool ... put the two suctions/dischargees on a pipe that will fit your new pump.
Posted on Aug 09, 2010
briones93
  • 119 Answers
SOURCE: I just bought an intex 15 x 48 metal frame pool
Here's the intex site with the manuals you may need. Should have the pool, pump and salt water system manuals for your 15 X 48.. Hope I helped?? If I did, please rate and add comment...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=13843&hid_windowname=null
Posted on Jul 26, 2011
Owners manual for cfr-50
in from pump to skimmer out from pump to filter in then filter out to returns
Jun 22, 2014 | Jacuzzi Filter Body,Cfr - 25
How to clean out filter
Shut off power,
Move Filter Valve Handle to the backwash position
Turn on Filter
Let filter run until the water is clear.
Turn back off and move the handle back to the filter position.
TIP: Replace your sand every two years!
For more info, go to:
http://www.oskopoolnspa.com
Sep 16, 2012 | Sta Rite StaRite Aboveground Pool Sand...
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
Unable to screw off top to pump. Which way is off and does anyone have any tips on getting the top unstuck?
If you mean the top of the inlet basket, it turns counter clockwise. Make sure that the pump body can't move, grab the large knurled ring and turn it.
If it needs persuading, tap carefully with a hammer and a block of wood on the inner sides of the grooves in the ring. The wood should be about 4 inches long and about 1/2 inch in diameter or so.
Gary
Dec 18, 2010 | Jacuzzi 34 Hp Lrc Swimming Pool Pump
Sir, Is there a drain plug at the base of the pump? I have a strong leak around where the "broken" drain plug is permitting water to leak around the threads in the housing--is this possible? Please...
Not too familiar with that exact pump, but pretty much all pumps have a drain plug on the front or side of the pot, and also in the impeller housing. these allow pumps to be drained for winter storage to prevent freezing. you should be able to get a replacement from the local pool supply store. there should also be an o-ring that actually allows the plug to seal. sometimes you can replaces this sometimes it's just easier to replace the whole plug
Sep 10, 2010 | Jacuzzi 34 Hp Lrc Swimming Pool Pump
How to install motor housing bracket on a jacuzzi pool pump motor or does it matter what side is up or down there are ridges on one side do the ridges go on top or bottom
The 'toothed' edge goes on top with the teeth facing towards the motor. You will also notice the small support arm in the plastic is narrower than in the other areas of the bracket. That lines up with the seal plates locating tabs so everything is then lined up correctly for the insertion into the housing.
Oct 08, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Air in my jacuzzi pool pump
Aug 02, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi pump not pumping
Jun 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Cyget In Ground Pool Pumps Logo
195 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
