Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
SPEAKER OUTPUT CHANNEL FAULTY, TWO MIKE CHANNELS DOWN
I HAVE A FENDER PASSPORT P.A. WHICH HAS RECENTLY DECIDED TO DROP A SPEAKER CHANNEL, ALSO TWO OF THE MIKE INPUTS. I SUSPECT THE SPEAKER PROBLEM MAY BE A FAULTY JACK SOCKET, BUT I NEED TO KNOW IF IT`S COOL TO OPEN THE FRONT TO GAIN ACCESS. ANY SUGGESTIONS WOULD BE APPRECIATED STEVE WHALLEY
  • Steve Whalley May 14, 2009
    Thank you, I am aware of the over-riding properties of channel one,
    but here only channels 1 and four are down. My system has been
    seen by a technician who thinks there may be a crack in one of the boards, which is ( A ) difficult to access and ( B ) uncertain as to avaliability. The speaker jack problem I understand but need to know if it`s cool and easy to take off the front control panel by removing the screws down each side to access the internal jack clip and bringing it back into alignment...would appreciate your savvy on this before I go ahead..Thanks again Steve.
  • Michial Gueffroy May 11, 2010
    If its still under warranty, you would be better off taking it ti a good musical equipment repair shop.
  • Fender Master
  • 5,603 Answers
These are a real pain to open. You have to remove the front panel to remove a shield to remove the back amplifier power supply area. The power supply is a switching type and has lethal voltages present. Working on this should be done using an isolation transformer. With your symptoms, it is likely one side of the power amp MAY be blown, but do check that the wiring hasn't fallen off and the jack itself. Two pairs of wires come from the power amp to the front panel jacks. document location of ALL the cables you disconnect as they CAN be confusing to restore.
Posted on Jul 26, 2009
    President:
  • 1,138 Answers
I forgot to mention that Fender has downloadable manuals and schematics under support. Channel one has a VIP feature with a threshold control for doing voice over music with a mike for announcements. Depending on the setting of the control channel one will take priority over the other channels. That may be the source of your channel problem.
Posted on May 13, 2009
  • Michial Gueffroy May 14, 2009
    I was hoping it was something simple. I don't have a Passport to take apart so I will have to guess. From the outside it looks like all the controls and jacks on the front are soldered to one board and protrude through the surface to be secured by nuts and washers. If you feel comfortable doing it then go for it. I'm looking at a picture of it and if the bottom panel is separate from the top panel all the better. Start by trying to determine how the panel comes off. Remove it slowly and carefully making sure that nothing comes unplugged inside. If you can get a good look at the back of the panel take note of any connectors that allow you to take the whole panel out and make a diagram or take pictures of everything so you don't get stuck later. Once you've got the panel out look to see how you can get at the jacks you want to work on. You may have to remove knobs, nuts,washers etc to get there. Again make careful note of everything as you go.You may discover that the jack is soldered to the board and you only have to resolder any broken solder joints. Bonus. If the jack is bent internally you will have to replace it by taking it to an electronics store. One that carries a huge selection of bare parts. The pin out on the rear of the jack and the depth of the jack are important so try to obtain as close a match as possible. If you want to you could also try removing the contacts in the jack and rebuilding it. Its easier to just replace it. You might also find the source of your channel problem with careful scrutiny. Cracks on this kind of circuit board if there is one can be bridged. They aren't like computer circuit boards with internal layers. Once you have the jack replaced use a bare phone plug and insert it and with a volt ohm meter test the solder side to make sure your connection is good.Keep me informed of your progress. It can be done. I didn't see a schematic on their website and its too bad as its easier to trace the problem with a schematic.
Have a fender squier 4 and wondering if you plug one side can you get full mano output?
What do you mean by "Plug one side"? Your guitar is mono....you plug into the channel with a mono signal cable....as long as you're panned to center on your channel strip, you would have full mono sound out...ie sound equally from both speakers. Usually you would be running your board in mono anyway.
Aug 17, 2012 | Fender Squier 4-channel Travel PA...
Power dont *** on
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Aug 08, 2011 | Fender Squier 4-channel Travel PA...
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
Greetings. My MG 250 DFX Marshall 100W amp behaves strangely... I had some problems with it lately. I've been using it for a few years in my flat, so it has not been used extensively in terms of power...
I believe the design of this results in what you are seeing... Check each speaker INDIVIDUALLY plugged into the MAIN output as plugging into the second jack shifts the tap of the output transformer to the 4 ohm tap which results in a 6 Db drop but now you have two speakers... the apparent level change will be almost unnoticeable.. Do comparision of the speakers individually using the MAIN jack. This is just the characteristics of the beast...
Jan 11, 2011 | Marshall Amplification Marshall MG250DFX...
I'm using an external reverb (T.C. Electronics Nova) through the effects loop and I can only get verb out of one channel (left I think) and in fact it seems that the "stereo" section (knobs etc.) have no...
The external effects when used would require an effect processor with left and right channels. You need four cables total for the effects... the two channels out to the effect unit and two cables to bring it back to the power amps.
Remember to use your pan controls if you want certain inputs to go more to either the left or right outputs.
Oct 15, 2009 | Fender Passport Deluxe 500watt Sound...
I want to add more speaker at my paspor fender 500
Run out of the stereo output jacks into a separate amplifier and speakers. The amplifier send jack only sends signal from the particular channel it is part of. In other words to get all the signals from all the channels you would need another mixer, amp and speakers. It is easier to use the stereo out which will give you all the signals. If you only use left out or right out make note of where your panpot is set for each channel.
Mar 03, 2009 | Fender Passport Deluxe 500watt Sound...
P 150 system fails when 2 or more inputs are used at once
If you have an owners manual make note that channel one has a VIP feature with a control. This feature makes channel one override the other channels and is used for voice over announcements. The manual explains how to use the threshold control to set this. It can be downloaded at Fender.com/support.
Feb 22, 2009 | Fender Passport Deluxe 500watt Sound...
LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
Fender passport model # 250 Used Only Twice!
go back in and find where the electrolitic capacitors connect to the board. They look kind of like a battery. One or both of them have broken loose from the main board, preventing any significant current from going to the output transformer, and causing overload. This is a common problem, and it does not take much rough handling to cause it.
where the break is is at the solder connection. Under a magnifying glass, the break will look like a little circle. Float fresh solder on that or any other large solder joints which may be cracked or broken.
Use standard precautions when working around high voltage.
Nov 08, 2008 | Fender Passport Deluxe 500watt Sound...
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
225 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
