Question about Logitech QuickCam Pro 4000 Webcam
I want this camara drivers - Logitech QuickCam Pro 4000 Webcam
  • 433 Answers
Http://www.logitech.com/index.cfm/435/269&cl=us,en?WT.ac=sc|downloads||dd
pick your operating and download...there you go...
leave rating....thank you
Posted on May 13, 2009
Me pide que instale el driver y esa camara no traia driver..
Hola.
Por favor mire si la camara es compatible con su sistema operativo. Una camara puede ser instalada automaticamente en vista y no ser compatible con XP.
Si la camara es compatible mire si los controladores son disponible en el sito de la camera (por ejemplo si la camera es Logitech mire logitech.com).
Alguna camara tiene un cd pequenito escuendido adentro del carton de la caja.
Intente llamar el revendedor si todavia no se soluciona. Si la camera es compatible con su sistema tiene que ser instalada automaticamente, o debe de aver el CD con el software.
Suerte.
Ginko
Apr 25, 2011 | Computers & Internet
A web camara não funciona e windows da sempre a mensagem pedindo a instalação de "look 316S driver installation. mas isso não contem no cd de instalação de camara
1st You download Webcam Driver.
A web camara nao funciona
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 10, 2010 | A4tech PK5
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil pmgibs1@verizon.net
Feb 20, 2010 | Dell Latitude D410 Notebook
Como le hago para instalar mi camara web ezonics
Feb 12, 2010 | Ezonics EZCam III Webcam
Como puedo instalar los drivers de la camara web. Cuando conecto la webcam, la pc me PIDE que Inserte el CD pero me dice que no encuentra los archivos . Puedo descargarlos de algun lado? es una GE 98650,...
ok necesitas bajar el driver directo desde la pagina GE 98650 y si es posible el software que viene con ella si es que perdistes el disco. Verifica si a camara es compatible con tu sistema operativo.. o si ya salio un update para ella que resuelva el problema.. Todo se resolvera bajando thel propio site de la camara las ultimas drivers y actualizaciones... Por favor dale a click que mi informacion te ayudo suerte o me avisas para darte otros pasos
Dec 28, 2009 | GE EasyCam Webcam
No funciona mi camara con el mesenger
reinstall the driver ...and the messenger ..this should solve the problem ...if you do not have any driver select it from the list for the correct operation system
http://support.acer-euro.com/drivers/notebook/as_5610.html
Use the wizard for to add the new hardware ...or ...first install the driver ..than restart and let it find and install automatically ....to be sure ..you can use the feature from the device manager
Nov 11, 2009 | Acer Aspire 5610-4648 Notebook
Driver Camara Jazz JDC26
Hola,
El driver de esta camara jdc9:
http://members.driverguide.com/driver/detail.php?driverid=611535
Click on the download link, and then choose Download this file by viewing a series of ads (no registration required)
and on the next 7 advert pages, just click 'Skip This' (under the adverts) and then enter the confirmation code and download.
Fixya!
Chris (ziraffa)
Dec 14, 2008 | Jazz JDC25 Digital Camera
Tiene el driver para esta camara MICROSOFT LIFECAM VX 3000
necesito los driver para esta webcam microsoft lifecam vx-3000 modelo 1076
Oct 19, 2008 | Microsoft LifeCam VX-3000 Web Camera
Cant get the camara to work
start from scratch here..plug and play should see that camera on USB port(try more than one if you have them) and then follow the install guides. You MAY need to remove those old install programs, through Add/Remove programs in control panel.
Patrick
Feb 06, 2008 | Microsoft LifeCam VX-1000 Webcam
Logitech QuickCam Pro 4000 Webcam Logo
65 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
