Question about Panasonic Televison & Video
Have no manual, need to change the colour manaully
The tv colour is yellow / green need to adjust the colour manually as the auto setting not doing anything
  • ozntom May 15, 2009
    Panasonic TX-29V31A
  • 35 Answers
Hi
Could you plz give more info on exactly what Panasonic you do have so i could try and find you a manual on it?
Kind regards
SlitWrists
Posted on May 14, 2009
I want to adjust the red,yellow, blue and green colors on my tv screen
Long time since there has been manual controls for individual colour adjustment at the back of a colour tv.
A tv is now a different type of computer and is run by software. Taking a guess I would say such if such adjustments are possible they are made with a laptop and more software...
Feb 05, 2018 | Televison & Video
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
How to set up the colour on my Panasonic Viera TV
http://service.us.panasonic.com/OPERMANPDF/TH42PZ80U.PDF
Here is a copy of your users manual, it tells you how to adjust the color on the TV, Magnets do not affect Plasma TV's. If your picture looks bad you might have a defective or failing part if you just need to turn the red up or down or make the picture more blue or green the users manual tells you how to adjust it.
Sep 10, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
How do I adjust the color
Hello
To adjust colour and other picture adjustments
[1] Press "Menu" key to display the main menu.
[2] Use cursor UP/DOWN keys to hilight [green]; Picture or sound ; whatever you wants to adjust, and press ENTER.
[3] Use cursor UP/DOWN keys to hilight [green] AUTO [for factory settings] or MANUAL to set picture settings according to your taste. Here you have to hilight MANUAL as you wants to set it mannualy. Press ENTER after selecting MANUAL.
[4] User cursor UP/DOWN keys to select the option you wanted to change.
then cursor keys to make adjustments of the selected option parameter according to your taste.
[5] When you have finished all the adjustments according to your taste, press EXIT key to return to normal tv viiewing. This way you can adjust the sound parameters also. Proceedings are all the same, but the option choose to hilight [green] must be sound. That is all. Ok.
Jan 12, 2011 | Sanyo DP26746 26 in. LCD Television
My picture seems so dark and changing the settings doesnt help.
you have to switcth off the auto bridtghness at the colour settings of you tv, then adjust it manually
Dec 05, 2010 | Sony WEGA KDL-42XBR950 42 in. LCD HDTV
Respected-Sir-ihave-pansonic-tv-14inch-and-top-domeno-tc1420t-but-problem-in-coloures-not-coming-properly-please-tell-me-about-it-thanks
Hello
You just retune it, it auto search mode. If colours have still problems, check its system adjustment. There is an adjustment for this. Just get into the menu option and come towards system set menu, and adjust the system to 'AUTO". You can just refer it to your TVs manual for this. This will retify your problem. Ok.
Nov 26, 2010 | Panasonic TX-29S90X TV
Can colours be adjusted manually? Some TV stations vary in colour content. How do I change the colour values?
you might find the colour & saturation levels controls. using your remote to set that up, check the tv manual... if you don't have one, you can likely find one on-line by doing a few searches.
Goog Luck... Ian
Oct 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I do not have a manual, how do I hook this dvd to the tv? I have one cord with yellow, red and white connections, cannot make it work. Thank you
If your dvd player is a high definition player you will need to connect your dvd to your unit with YPbPr connector cables. the come with 5 or 6 jacks (red,green,blue,yellow,white) (sometimes you may find and extra red jack do not plug the 2nd red jack in. Ground it so that way it's not touching any of the other input jacks). Change your input source whenever you go to use your dvd player or turn your auto source on. You can retrieve a manual from your tv's manufacturer website. It will be available for download.
Aug 04, 2009 | Akai DVPS7000 DVD Player
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
