Priner carriage does not locate to enable change of cartridge
My recently purchased Epson SX105 printer has 'low ink' light flashing, but when I follow the instructions on the printer housing (which are not very clear, I must say), the carriage of the printer does not locate in the space to enable access to the cartridges, for replacement to be done. The carriage seems to zoom to and fro in an odd way, compared with the previous, H.P printer, I had for years. Please advise. Many thanks Colin Parkinson
Enter windows printers from the start button, then right click on the desired printer, then choose properties, then maintainence, then replace ink cartridges, easy this way
Posted on Sep 10, 2009
    Genius:
  • 1,447 Answers
Hi
Try to turn it off and turn iit back on then press and release ink button that has the tear drop symbol if theres any, that should position cartridge holder where you can replace it.
Pls update me. thanks
Posted on May 13, 2009
My r230 is having this trouble: the two red lights are blinking.
If the Ink Out light flashes, the printer is getting low on ink; if it is on solid, the printer is completely out of ink and you need to replace the cartridge; if it is flashing rapidly, the printer detected a print head unit or ink cartridge installation error. If the Paper Out light is on solid, you need to install paper in the printer; if it is flashing, the printer detected a paper jam. When both the Ink Out and Paper Out lights are on solid, the printer thinks that there is a carriage error; if both lights are flashing, there is a fatal error and the printer will need to be sent in for service Source(s): http://www.epson.com/cgi-bin/Store/suppo...
Mar 06, 2011 | Epson STYLUS R230 InkJet Photo Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
Epson r230
Nov 02, 2009 | Office Equipment & Supplies
Epson stylus C70: all lights flashing
check to see that the cartridge is moving freely along the carriage. the carriage might need to be cleaned.
Jul 31, 2009 | Epson Stylus C70 InkJet Printer
Changing an ink cartridge Epson stylus sx105
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX105-_E
that guide shows how to change the cartridges and no you dont have to wait untill they have run out to change the cartridges
May 15, 2009 | Epson Stylus NX400 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
No response
If you´re pressing the ink button and the carriage still does not moves is cause the level of the ink is low, but it does not finished yet. You must use the printer more, then the red light will stop to blink and hold on, then you´ll be able to change the cartridge.
Apr 19, 2008 | Epson Stylus C60 InkJet Printer
207 people viewed this question
k24674
jasbo
jasbo
