Question about Zyxel P660HW-D1 Router
Port forwarding not working in ok firmware AGL6 or later
Port forwarding not working in firmware after AGL.4. Something wrong with the firewall. Everything works fine in AGL.4 but with firmwares AGL.6 and AGL.7 the port forwarding through the firewall doesn't work. Disabling the firewall and it works. Zyxel's support in northern Europe refuses to acknowledge this problem, so had to do a rollback to AGL4...
I'm just doing a basic port forwarding NAT + RULES in the firewall. No access from WAN to LAN to my IP-cameras. As said above with AGL.4 everything works fine...
According to my very thorough testing some weeks ago, P-660-HW-D1 port forwarding is really very broken.
The worst thing is that not only does the port forwarding work properly, it lets packets to LAN addresses where they're not supposed to go. This means you're not safe behind LAN.
Firewalled or not, AGL.6 or AGL.7 shouldn't be used at all in my opinion, they're unsafe. When in routing mode, and having several LAN machines behind one Zyxel switch port (i.e. separate switch attached), I found that the port forwarding is completely broken.
I have contacted Zyxel Finland about this issue two weeks ago, and they initially thanked for the finding and said they're passing the issue onwards and investigate it.
The best current solution is to downgrade to (also very buggy) AGL.4.
Posted on Aug 06, 2009
  • 115 Answers
Zyxel support all over the world doesnt acknowledge the problem
Posted on May 13, 2009
Tip
Solution for War Craft 3 behind Linksys routers.........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G Broadband Router
Tip
How to Upgrade Firmware of Linksys routers........
Example:
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
Port forwarding
I understand your problem..To fix this issue all you have to do is,You should open the port numbers on the belkin router still if its not working then
1)disable firewall on router and check..
2)disable anti-virus (Norton,Mcafee etc) & check
3)Confirm the model number & version of your router and check for firmware update
A It may be quiet difficult for you to do all this.please call toll free number"belkin"
Hope this is help full for you
Apr 11, 2009 | Belkin (F5D7230-4) Router (587009)
Yellow light with bitcomet 1.10 using xp and netgear dg834g
go to your router setting and try to disable all firewall, if still not work, check your port forwarding setting, it could went wrong, different router have different name for port forward. must set bitcoment port ..let say 65535 and set port in router 65535.
Mar 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My F5D7230-4 Belkin Router Virtual Servers power forwarding broke
Hi there!
Have you checked the Windows Firewall settings? If it is On, try turning it off and attempt the connection with RealVNC. If the problem persists, try adding an Exception to the Windows Firewall, just as an added troubleshooting measure.
Click Start, navigate to Control Panel, double-click Windows Firewall, and open the Exceptions tab. Look for a RealVNC entry. If you don't see one, click the "Add Port" button, type RealVNC as the entry name, and 5900 as the port number. Select the TCP radio button, click OK and then OK once more. Attempt the RealVNC connection again.
I hope this helps! Feel free to reply with results or further questions.
Feb 18, 2009 | Belkin (F5D5231-4) Router
Port fordwording is not working for Radmin port 4899
when you do port forwarding you must know or have a static ip of the device for the application. For example, if you want to forward port 3074 for your xbox live, you need to enter also the xbox ip address on the port forwarding page. Port forwarding is like opening a port on your firewall for that specific application. Make sure also that you have the latest firmware of the router.
Regards
Mar 07, 2008 | Linksys WRT300N Wireless Router
Xbox live NAT
Has your Xbox IP changed any?
Your on a DHCP right?
Oct 19, 2007 | NetGear WGR614 Wireless Router
Help stressing out
If you manage somehow to access your player through the computer, run a firmware upgrade. Get the firmware + instructions here - http://www.sandisk.com/Retail/Default.aspx?CatID=1301 Take care to follow the instructions.
Jun 18, 2006 | SanDisk SDMX1 MP3 Player
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both Both IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application FTP SMTP POP3 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both TCP IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue Restart your computer
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Zyxel P660HW-D1 Router Logo
579 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
