Question about Maytag PAV3240A Top Load Washer
Top load washer
My washer will not engage the spin cycle
  • 5 more comments
  • maxarooney Nov 03, 2007
    i am having the same problem...will agitate and drain but not spin out
  • Anonymous Nov 03, 2007
    its not spinning properly, Where can i get the user manual?
  • jeska_661 Dec 29, 2007
    my washer will agitate but will not spin
    my washer will engage and spin after the final rinse
  • cooleyman May 09, 2008
    it will adgitate but wont engage to spin
  • Anonymous Oct 07, 2008
    Same problem, will agitate but not spin.
  • Anonymous Oct 28, 2008
    The wash cycle ends and machine shuts off but cycle has not really gone thru the spin cycle - so you open the washer and it is still full of water - you must turn the dial around to the spin cycle again so that it drains and spins.
My maytag washer will spin after the wash cycle but after the rinse cycle to final spin it will not spin them dry and leaves half the water in i let it sit a while and go back and put on all spin cycles tell one works thanks send me a fix it solution Linda
Posted on Nov 17, 2008
I am having this same issue, has anyone found the solution to this issue?
Posted on Jan 02, 2008
  • Fixologist Jan 02, 2008
    Sorry I added a solution rather than a comment, first time posting.
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
My kenmore washer spin cycle will not engage / motor is spinning but not engaging prop to spin out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Kenmore Washing Machines
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Maytag PAV3240A Top Load Washer Logo
353 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
