Question about Behringer MS20 Digital Monitor Stereo Speakers Headphones
Broke one end of the cable that connects my 2 behringer ms20 speakers.Which replacement part do i need?
    President:
  • 1,138 Answers
What input were you plugged into? If you are talking about the cable that connects the two cabinets from right speaker to left speaker, it looks like a standard RCA cable to me. It basically connects the signal content from the right cabinet to the left cabinet. It should be a shielded unbalanced RCA to RCA cable.
Posted on May 13, 2009
The piece that holds fuse broke
You can mke one. In stores, they sell little fuse holder with a wire at each end. It should replace it if you don't know how to do it, ask a friend who knows how to fix it. It is easy to fix. Best of luck. Serge Lavallee.
Feb 17, 2014 | Behringer Eurolive B212A Speaker
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
How to hook up speakers? Sound sounds muffled
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I broke the passive biamp switch off the back of my 1800 x subwoofer. i have been using it like that but now its not working. can i buy just the back panel with the switch on it or do i have to get another...
You can get replacement switches. The internals of the switch probably broke and no longer connect causing the speaker to not work. FullCompass.com is the Behringer parts distributor but they may direct you to first call Behringer to get a part number for the item.
Feb 14, 2011 | Behringer EUROLIVE Professional B1800X Pro...
How to in install the speakers to it
You will need either powered speakers or an amplifier for the speakers. If you have powered speakers with built in amplifiers, use balanced audio connection cables from the MAIN outs of the mixer to the speakers, Use XLR or 1/4 inch TRS cables.
If you do NOT have powered speakers you will need amplifier as well and speaker cables in addition to the audio connection cables above.
Dec 29, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
How can i connect a behringer eurorack to a mbox 2 for protools
basic speaker cable from the eurobacks speaker output to the di selection on mbox... in one of the input slots
Jan 15, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
The Amplifier will have wierd, notched, circular speakon cable connectors on the back, two, one for main left and one for main right. Press the button in on your speakon cable connector and twist it and lock it into place on the amplifer for right and left attachments, then do the same to your speakers.
Hopefully this helps.
Michael Lazar
http://www.AudioholicBlog.com/
Aug 27, 2008 | Behringer EUROPOWER EP1500 Car Audio...
Behringer MS20 Digital Monitor Stereo Speakers Headphones Logo
191 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
