Question about PC Chips M848A V5.0 Socket A and FSB400 DDR400 SIS746FX 963 L Motherboard
Audio problems. audio conn. from 1 to 10 i use 6 for yellow, 8 for green, 9for black and 10 for white m.b m848a
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
Nov 03, 2012 | Cars & Trucks
Radio wires in 97 continental lincon
1997 Lincoln Continental Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Brown
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6" by 8" Speakers
Car Audio Front Speakers Location Doors
Left Front Speaker Positive Wire (+) Orange/Light Green
Left Front Speaker Negative Wire (-) Light Blue/White
Right Front Speaker Positive Wire (+) White/Light Green
Right Front Speaker Negative Wire (-) Dark Green/Orange
Car Audio Rear Speakers Size: 6" by 8" speakers
Car Audio Rear Speakers Location Rear Doors
Left Rear Speaker Positive Wire (+) Gray/Light Blue
Left Rear Speaker Negative Wire (-) Tan/Yellow
Right Rear Speaker Positive Wire (+) Orange/Red
Right Rear Speaker Negative Wire (-) Brown/Pink
Aug 23, 2012 | Pioneer Car Audio & Video
How do I straight wire a CD player in a 2000 mustang?
Constant 12V+Green/Yellow Switched 12V+ Yellow/Black Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Deck Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 17, 2012 | Ford Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
PC Chips M848A V5.0 Socket A and FSB400 DDR400 SIS746FX 963 L Motherboard Logo
137 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
