NOT BLOWING COLD AIR
WORKED FINE YESTERDAY..ITS AT 65 NOW AND NOT BLOWING COLD AIR..FILTER IS CLEAN ..VENT IS CLEAN..FAN AND EVERTHING IS WORKING FINE...NO NOISES! WHATS WRONG WITH IT?
  • 83 Answers
Compressor is not working. either a relay or the compressor is malfunctioning. You need a technician to check it out.
Posted on May 13, 2009
  • 4 Answers
Is the compressor motor running off the belt of the motor? Check the fuse for the A/C. Will you have everything running, grab the pipe that runs into the firewall in the engine bay to test for refrigeration effect. If the compressor is running, but no cooling affect is on the pipe, it means that the refrigerant has leaked out of the system at its weakest point. In this case, you will need to take it into a licenced repairer. Good Luck.
I have a 1975 k5 blazer and it blows cold air it worked fine last year but now it only blows cold air even on the defrost setting what can the problem be and how can I fix it?
A vent flap actuator probably needs to be replaced. It's what moves your vent flaps from heat to A/C or to plain "vent air" when you change settings.
The discussion in the link includes vent flap actuators. Unfortunately, they also include the infamous no low speed fan problem too.
Cannot get any air from dash vents while defrost and floor vents work fine...
Your particular actuator will be a different one than they found.
They're all a absolute pain to get at because they can be well buried in the dash. I would start looking under the dash on the passenger side, that's where most of the air control is. Cannot get any air from dash vents while defrost and floor vents work fine...
Nov 14, 2016 | Cars & Trucks
A/C issue in Chrysler Pacifica
You will need to remove the dash to get to the duct work just to clean it properly. You may have some damaged blend doors that will need to be replaced.
Mar 12, 2017 | 2005 Chrysler Pacifica
I have a 2003 dodge caravan and the front air blows cold but the rear vents are blowing hot air what could the problem the fans are both working fine
The problem may just be with the evaporator unit found at the passenger cabin. At times you may just need some cleaning to get it working.
Jun 06, 2011 | 2003 Dodge Grand Caravan AWD
The dash air vents in my 2000 Venture will not blow much air
Dont waste your time with HAYNES. You can get ALLDATA on a CD disc from any Auto Zone store. Its a reprint of the OEM manual.
Dec 17, 2009 | 2000 Chevrolet Venture
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
AC is on but the air isnt cold
You may not have all components working, check to make sure the outdoor fan is working. Also listen closely to ascertain that the compressor is coming on,
Jul 10, 2009 | Hunter Heating & Cooling
A/c vent issue
heater blowing cold when engine idleing,works good when rpm are up. what is problem? pete
Jun 06, 2008 | 1997 Nissan.5 Altima
Heating & Cooling Logo
617 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
