Question about Samsung SF-560 Plain Paper Laser Fax
Receiving telephone calls on other house phones
I have just been given this machine , to receive my next days work.   It receives the faxes, but we are not able to answer our other phones in the house.  I have tried all the alternatives given in the manual all to no avail.
The machine is connected via filters which we have for our broadband connection.  Can you help, thank you.
                         Yours faithfully,
                            Mr J W Thomas.
e-mail address------  jeffr11.thomas@tiscali.co.uk
  • jeffwt Oct 16, 2007
    Could you explain how to set fax machine to MANUAL RECEIVE no explanation how in handbook
                                Yours
                                   Jeff Thomas.
  • 1,113 Answers
You need to set fax to MANUAL RECEIVE so the fax doesn't answer all calls.
Posted on Oct 15, 2007
  • Soulvisitor
    Soulvisitor Oct 16, 2007
    This will; set it to manual or tel mode, fax will ring untill answered.
    1 Press Receive Mode.
    2 Press and hold Receive Mode until “Tel” displays on the bottom line.
    You may have to repeat this action once or twice depending on the
    mode you’re in.
    3 When you receive a fax call, pick up the handset or press On Hook
    Dial.
    You can hear a fax tone or voice from the remote machine.
    4 Press Start Copy/Fax to receive the fax.
    The machine begins receiving a fax and returns to Standby Mode when
    the reception is completed.
  • Soulvisitor
    Soulvisitor Oct 17, 2007
    Manual receive mode is the same as setting it to Tel mode soory for confusion, different brands use different terms
Cannot receive a FAX but can send FAX on a HP Photosmart C7180 All-in-One
are you using the same line for fax and phone???
are you using a Telephone Answeing machine or a Voice Mail??
However you can follow the following steps
1. Press the power button to turn off the HP fax product.
2. Wait for 20 seconds, and then press the power button to turn on the HP fax product, and then connect one end of a two-wire telephone cord to the telephone jack and the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Make sure that there is plain white paper in the input tray.
4. Press the Setup button on the product Control Panel.
5. Press the down arrow to select Tools, and then press OK.
6. On the Tools menu, press the down arrow to select "Run Fax Test", and then press OK. The Fax diagnostic test prints.
7. Review the report.
If the test lists faxing issues and solutions, the fax test failed.
Try the steps on the printout to troubleshoot the issue as the report is specific to your product and faxing environment.
Repeat the fax test after fixing the listed faxing issues to make sure the test passes. Try to receive a fax.
Okay, next, we need to make sure that the Auto Answer feature is turned on by following the steps below:
When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls.
1. Press the Setup button on the product Control Panel.
2. Press the down arrow to select Basic Fax Setup, and then press OK.
3. On the Basic Fax Setup menu, press the down arrow to select Auto Answer, and then press OK.
4. Press the down arrow to select On, and then press OK.
5. Try to receive a fax.
Since the issue persists, the problem could be due to some conflicting telephone services.
The following telephone company services might block or interfere with incoming faxes:
Distinctive Ring Service: A distinctive ring service, if it is available from the telephone service provider, often resolves this issue.
* Voice mail: It is possible to use the fax in manual receive mode while using a voice mail service. For manual receive mode, turn off auto answer and press "Start Fax Black" or "Start Fax Color" on the control panel before the voice mail picks up the line to start receiving the fax.
* Call waiting: Do not use a call waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
* Privacy block
* Security screen
* Anonymous call rejection
* Privacy manager
* Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to the HP fax product, contact the telephone service provider for its recommended solution.
After addressing any existing conflicting telephone services, try to receive a fax.
Try contacting telephone people
try changing the settings below
2. Press the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Fax Speed, and then press OK.
4. Use the down arrow to select Medium, and then press OK.
5. Try to receive a fax again. If the HP fax still cannot receive a fax, try lowering the fax speed even further
Next, change the "Rings to Answer" setting on the HP fax by following the steps below:
2. Press the right arrow key to select Basic Fax Setup, and then press the OK button.
3. Press the down arrow to select Rings to Answer, and then press OK.
4. Use down arrow to select the desired number of rings, and then press OK. you cn change the rings to answer to 6 if your telephone answering machine picks up the call after 4 rings.
If the HP fax still cannot receive a fax, change the following steps
2. Use the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Error Correction Mode, and then press OK.
4. Use the down arrow key to select Off, and then press OK.
1. Plug the telephone cord directly into the telephone jack and not through any other device.
2. If present, remove any splitters or other devices attached to the line, except for a DSL filter.
3. If the telephone cord is over 3 m (10 ft) long, move the fax closer to the telephone jack, and then use a cord 3 m (10 ft) long or shorter.
4. Connect the other end of the telephone cord directly to the back of the HP fax product into the port labeled 1-Line.
5. If other devices such as, telephone answering machines or computer modems, are attached to the telephone line, remove them. If devices attached to other extensions of the same telephone line are present, remove them for this test.
6. Try to receive a fax.
If removing telephone devices and connections allows the HP fax product to receive faxes, this indicates interference from one or more of the removed devices. Interference can be caused by incompatibility or by using too many other telephone devices at once. Telephone devices can be added back but test after adding each to make sure that they do not start to interfere again.
If the HP fax product still cannot receive a fax after removing other devices, continue with the following steps:
7. If a DSL filter is needed on the telephone line, change the DSL filter and then try to receive a fax. If the HP fax product still cannot receive a fax, proceed to step 8.
8. If a new telephone cord has not been tried, change the telephone cord to a new two-wire telephone cord, and then try to receive a fax again.
if it does not resolve then perform the following steps
1. Disconnect the power cord from the back of the product.
2. Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel.
3. Connect the power cord to the back of the product and then release the buttons when the product turns on.
4. The product resets to factory defaults.
As a last step, test in another location by following the steps below:
If possible, move the HP fax product to another location with a separate telephone line (another house for instance).
Try to receive a fax at that location, and if you are able to receive faxes from the changed location, then your telephone line should be tested.
If it resolves well and good if it does not then service the printer
Dec 12, 2012 | HP Photosmart C7180 All-In-One InkJet...
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
2 Set the answering machine to answer incoming calls before the printer does.
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Samsung SF-560 Plain Paper Laser Fax Logo
66 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
