Question about Belkin (F5D5231-4) Router
My Belkin router keeps lossing connection or 'hanging'?
Hi, I have a Belkin ADSL2 modem with wireless G router which has the same problem pretty much every day. It loses connection - sometimes the web light goes out and sometimes it stays green and says connected but is 'hanging'. In both cases I have to tur the router off and re-boot. Usually this corrects the issue, on a number of occasions it has taken multiple re-boots to get connection again. It also doesn't seem to matter whether I use the router wirelessly or not the problem persists. Have you any ideas? Please keep them fairly simple as I am not a computer expert!
  • 611 Answers
Just update the firmware in the modem+router then your problem will solve it
Posted on May 14, 2009
Hi, ADSL2+Wireless Modem Router was set up, it was good, but without the yellow cable, it was not connect to net why? Thanks, looking forward of your reply.
Because you need to match the security setting on the wireless router to sign on to the wireless portion of the modem. If you flip it over, you should see a sticker with WEP on it- write that down, view available wireless networks, and enter in the key from the sticker when prompted- at that point you should be able to use the wireless portion of the modem
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
May 31, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a belkin router, cordless phone interferce
cordless phones and wireless routers transmit on the same frequency. Move the router away from the cordless phone if it's near, if not try changing the channel on your belkin router
Now if your WIRELESS connection drops, when the phone rings it's usually because of this:
You have a cordless phone in your house that is using the same channel as your wireless router. Now routers are generally quite different so there's no one way to fix this. Just look up your make and model of modem on Google and find out how to change the channel on your modem. It's pretty straight forward and not very time consuming to fix.
Also one thing to note is that you shouldn't automatically jump to the highest channel that you can because your wireless card may not be able to go that high.
Apr 18, 2010 | Belkin (F5D7230-4) Router (587009)
Compatibility with high speed ADSL2 Broadband
Yes, Linksys WRT160N is 100% compatible with ADSL2. Linksys WRT160N is a Broadband router.
you will not be able to use the linksys WRT160N, as an ADSL2 modem router. you should be using an ADSL2 Modem separately and connect the cable from the modem to the Linksys WRT160N. Hope this clarify the doubt.
Apr 02, 2010 | Linksys WRT160N Wireless Router
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Mar 20, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Jun 02, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Re- belkin adsl2 plus wireless router
i think u have an adsl modem + router u have to connect the phone line on the back where it say. yes it can be used with other broadband services in that case you have just config it.
Mar 05, 2009 | Computers & Internet
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it...
no, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Oct 03, 2008 | Belkin Computers & Internet
Belkin (F5D5231-4) Router Logo
630 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
