Question about PC Chips M848A V5.0 Socket A and FSB400 DDR400 SIS746FX 963 L Motherboard
Connection probl. on m.b need a manual
Maybe i`ve connect wrong. Need a manual for m848a m.b got audio probl.
  • michael170 May 13, 2009
    there are audio connect. from one to 10 on the same.
    I use nr 6, 8,9,and 10 for yellow nr.6 green for nr 8, black for nr 9 and white for nr 10
  • Yannick Verhoog May 11, 2010
    What did you connect wrong to the mobo?
Putting the base together
When i put my Fieldcrest Armoire together the base connected fairly easily to the other 3 pieces. Are you sure that you followed the instructions very carefully and haven't mistakenly mixed up some of the wooden pieces? I would re-read the instruction manual very carefully again and if you are sure you've followed the correct steps, you can contact the place where you bought it as maybe they gave you a wrong piece. Good luck.
Sep 29, 2012 | Foremost Fieldcrest Armoire - Espresso
MSI PM8M-V Motherboard front panel wiring problem. Need manual for connectons diagram to connect frontpanel audio wiers and make check-up for other connections. Didn't found the manual from msi...
You can download it from HERE, the manual is inside that winzip file as a pdf file. And the details about the Front Panel Connection is on page no. 24 of the Manual. Here's a screenshot for you:
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jul 22, 2011 | MSI PM8M-V Motherboard
How do I connect it so that my tv sound comes through the FR 984?
You need to connect the Audio Output from your TV (if it's got one) to the Audio Input on your Home Theatre.
You then need to change the TV settings to select the Audio Output instead of it's speakers and change your Home Theatre settings to select the Audio Input where you've made your connection.
Jul 16, 2011 | Audio Players & Recorders
I have a Mitel 5212 IP phone that i've connected to one of my satelitte networks upcountry. My problem is that every time i dial a number, i can hear the other party but they can't hear me. I tried...
one way audio is always a network issue. maybe there is a gateway wrong or a UDP port not open. If the remote site is connected with a MPLS circuit it could be missing a route to get back.
Jul 06, 2011 | Mitel 5212 IP Phone
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
I need a manual for my gigabyte ga-t671mg motherboard so that i can connect the on /off switch
There isn't a manual available for it, as it is an OEM motherboard in pre-built PCs BUT I've the same motherboard in a Packard Bell iMedia J2422 (now in a BitFenix Colossus case!). You connect the power to the bottom left, reset top left, h.d.d led top right, power led bottom right into the Front Headers (F_Panel) - which is located on the bottom right hand-side of the motherboard. My board has writing underneath the header telling you what connects where, maybe yours does too? Hope I've helped.
Mar 24, 2011 | Intel Motherboard
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
M848a v 5.0 unable to get front usb connection after all software installed. double checked connections
you need the wire diagram of case to plug in the right way you can fry the board if not right jim
Feb 17, 2010 | Computers & Internet
Hi i have a problem with panel1 on M848A v5.0 motherboard i cnt seem to work out how to connect the case properly it looks like this ()()()() ()()()()() i have the power switch, reset switch, hdd led and...
OK, this is for all the idiots who reply and offer NOTHING. You need more info, model and ver? HE ALREADY GAVE ALL THAT INFO.
Type "M848A v5" in google and you will see it is a PCChips mobo AND the manual is here:
http://download.ecsusa.com/dlfilepcc/manual/848Av50.pdf
BUT the manual DOES NOT HAVE THE PIN-OUT, so the manual is worthless...
Here is the pin-out:
(2)(4)(6)(8)
(1)(3)(5)(7)(9)
...and thanks to guntotenmadm
Aug 28, 2009 - The pin layout on the MB are color coded. There is green, orange, pink, and blue. I'll start with the green pins 2 and 4 these are for the power led wires, bottom pin #2 is the + pin (your green wire). Pin #4 is - (your white wire). Now the orange pins, pins 1 and 3 these are for the HDD led. The bottom pin #1 is the HDD + pin (your red wire). Pin #3 is the HDD - (your white wire). Now the pink pins, 6 and 8 these are for the power switch. Pin #6 is the + pin (your orange wire). Pin #8 is the - pin (your white wire). Now the blue pins, 5 and 7 these are for the reset switch. Pin #5 is the - (your white wire). Pin #7 is the + (your blue wire)."""
May 18, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Cmos clock will not set !
Is the cmos clear jumper in the wrong position? if it is it will drain the battery and mess up the clock, You may have to flash the eeprom with a newer version BIOS obtainable from the manufacturer, check their website on this to see if it is a known issue ( I have seen this on multiple other manufacturers main boards). If this isnt it it is possible you have a bad clock chip
Dec 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
PC Chips M848A V5.0 Socket A and FSB400 DDR400 SIS746FX 963 L Motherboard Logo
161 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
