Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Dish washer has soap and "gritty" deposits on the bottom
Help what do i do about this???
Re: dish washer has soap and "gritty" deposits on the bottom - Frigidaire 24 in. FDB126RB Built-in Dishwasher Dishwashers
Use rinse aid.
Posted on Oct 14, 2007
0 characters
3 Points
My dishes come out with a gritty sand all over them.
If you live in an area with hard water, the grit is probably hard water deposits. Dishwasher detergents no longer contain phosphate, so the detergents often leave behind hard water deposits on your dishes. There is a great solution at
Oct 15, 2012 | LG LDF6920ST Stainless Steel 24 in....
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My GE Eterna Series 3 Quiet power is not cleaning our dishes. Mostly the dishes on the top row has lots of stuff found in the glasses and mugs. YUCK!! I ran it for a minute and there is just water in...
I just took mine apart (bottom turntable, screen, etc.) and I was disgusted by the grime and gum that was clogging everything. I think it was keeping all the water a gritty white, which constantly left residue. I am currently running a load... hope that the "clean" dishwasher actually washes my dishes now!
Nov 18, 2009 | Maytag Dishwasher
Water & soap was coming out of the dishwaster. Replaced the seal around the door. Ran again on a pots & pan cycle to clean & it worked fine. Ran a normal cycle with dishes & soap &...
That sounds like the float switch is acting up. It is a mushroom looking device on the bottom that has a movable (up and down) plastic cup over the top. With the machine off, take the lower tray out and lift up on the cup--you should hear a faint 'click' when it nears the upper limit. It should also drop to the bottom when released. There may be food deposits that interfere with the proper movement of the cup. Are you using dish washer detergent only?
Aug 15, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishes on the top rack not cleaning properly
Had similar problem with our Maytag dishwasher--we removed all spray and screen components to the inner case, cleaned the intake screen below the lower spray arm, repaired a split upper spray arm, and inspected everything for cracks or other distortion. All of this helped some, but finally improved things by changing from liquid detergent to a "packet" type. Our water is somewhat hard and builds deposits on the screen at the bottom. Run a no-dish cycle with a cup of white vinegar in the bottom.
Aug 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Hotpoint Auqarius dishwasher. I have resentley moved house and reconnected the machine. it works through programme fine but is sometimes leaving dishes gritty and not quite clean. I have cleaned filters,...
It sounds like there could be a gritty deposit in the bottom of the system. At the start of the cycle the unit takes in a set amount of water and recycles it around to the drying phase.
Try and run the diswasher a few times with no items in it - this will may help to flush it out.
If the gritty deposit coloured white this could be that your new home has more limescale in its supply. Try getting dishwasher tablets with limescale protection to see if that helps.
Finally, please ensure the spray arms free to rotate on each cycle. Failure to do this leaves grit on certain items and not others.
Please dont forget to rate.
Jul 07, 2008 | Dishwashers
Dishwasher Issues
I would try using a different soap or less of your current soap.
Jun 21, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
47 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike Cairns
Mike Cairns
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
