Question about Nintendo Wii Remote Controller
Communication with the Wii remote have been interrupted; new batteries inserted.
After loading CD, I get a message that read: communication with the Wii remote have been interrupted.even after I'd change to new batteries. So how can I solve this problem.
3 Suggested Answers
  • 19 Answers
SOURCE: communications with the wii balance board interrupted
dont push your feet hard or the batteries might come off of the cap isnt put on or the batteries are fully used
Posted on Feb 13, 2010
ThEDSfan
  • 57 Answers
SOURCE: I cannot connect the wii fit board to the console.
Replace the Wii Remote batteries. Grab 2 AA size batteries, and insert them into the Wii Remote properly. Look closely at the battery slots, and you should see 2 little battery icons. Insert them correctly according to the icons. Communitcations with the Wii Remote should be restored. For more information and solutions, read page 34 in the Wii Operations Manual: System Setup.
Posted on May 16, 2010
Epic Mickey 2 wii on wii u remote and nunchuck problems.
Do you think it's the battery? Or maybe the back. If the wii loses power, either the game you are in will immediately pause or it will continue moving in the same direction you pointed it in before the wii lost power
Apr 23, 2014 | Video Game Consoles & Games
Charge the battery fully, and ensure the nunchuck is clean.
We received the wii system w/ a battery charger included ,but there were no instructions as to whether you can recharge batts. w/o having the them in the unit ,what the red,green light means what the...
Installing the Batteries
    Important Note: If you would like to use rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
  1. Remove the battery cover on the back of the Wii Remote and insert two AA batteries, using the plus (+) and minus (-) guides in the Wii Remote's battery compartment to insert the batteries in the proper direction.
  2. Be sure to insert the minus (-) end first when inserting new batteries, and remove the plus (+) end first when replacing the batteries.
  3. Replace the battery cover.
  4. Go to the Next Step (Wearing the Wrist Strap) >
  1. Place your hand through the wrist strap and hold the remote firmly in your hand. wiiremotewrist1.gif
  2. Slide the strap lock towards your wrist so that the strap will not fall off. Do not over tighten the strap lock so that it's uncomfortable. It should be tight enough to hold the wrist strap in place. wiiremotewrist2.gif
    Go to the Next Step (Syncing the Wii Remote with the Wii Console) >
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Jan 23, 2011 | Nintendo Wii Console
Cannot read Wii CD but can read GameCube CD
Have you tried more than one Wii game?
If you have tried more than one Wii game and none will read,
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Sep 21, 2010 | Nintendo Wii Console
I can't sync my board to my remote
You have to insert a wii fit game and bypass all the stuff until the game is ready to play.Open the battery compartment on the Wii board and open the large door on the front of the Wii console.Press the sync button on the board,then press the sync button at the top of the console compartment.The fit board light should stay steady blue.If it doesn't,try it again.When the fit board stays steady blue,it is synched.
Jul 13, 2010 | Nintendo Wii Fit for Wii
Communications with the wii balance board interrupted
Feb 12, 2010 | Nintendo Wii Fit for Wii
I cannot connect the wii fit board to the console. I get as far as the pushing the red buttons on the console and the wii fit board and then come up with an error communications with wii remote have been...
Aug 24, 2009 | Nintendo Wii Fit for Wii
Bowling pinbusters
Check your batteriyes by hitting the home button it will say all the battery power on the bottem if the batteries are low it will say that
May 03, 2008 | Nintendo Wii Console
Nintendo Wii Remote Controller Logo
2,043 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
