2005 Yamaha DT 125 RE Logo
Posted on May 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha dtr125 starts then cut out seems like battery
Cellonoid clicking but the starter motor does not work
tried another battery
also the fuse near cellonoid has popped a couple of times
thanks
  • fothergillj May 14, 2009
    cheers mate
    also it seems ok to the celonoid but the starter motor is not working if it is stuck in will it still bump off as we have tried and the back wheel seems to lock up
Murtaza Akberali Versi
Level 3:
  • Yamaha Master 767 Answers
  • Posted on May 13, 2009
Yamaha Master
Level 3:
Answers
767
Questions
Helped
356164
Points
2180
It seems the starter motor is faulty.
remove the starter and overhaul it.
  • Murtaza Akberali  Versi
    Murtaza Akberali Versi May 14, 2009
    The best way is to remove the starter and check it.
1helpful
My opel corsa 99 cut out today and now it wont even turn over jst a little click when the key is turned the battery seems fine lights and radio come on when the ignition is on but if i push start it will...
Hi just because the lights work does not always mean the battery is ok. It takes a lot more power to crank the starter.
Generally that clicking will be either the battery or the starter motor. I would suggest if you can try jump leads and if it starts problem is battery, If not problem is most likely starter motor. For a possible third thing to check Make sure the battery leads are tight.
Cheers Mike;-)
1helpful
Gilera nexus 500 clicking near battery and wont turn over
Check your starter. It sounds like this is the culprit.
68 mustang new sylenoid, starter,battery. No power. Checked every wire everything seems to look ok. Any ideas would be helpful
Rechecked all battery connections? Check the fusible link or links in the wiring around or near the battery, maybe off the fender mounted relay. Fusible links are old time variants of regular fuses. If they burn out, they can be cut out and replaced. As part of the power distribution, they are near the battery source.
Yamaha atv wont start new battery was working
first check the starter relay it could be faulty,,,then check the starter motor,,that could also be the fault,,,my gess is its the motor?
2answers
Replaced starter relay and stater in yamaha 1100 2001 v star
Charge battery to full, start in neutral, still clicks? Bad ground, or bad connection. Jump starter solenoid with screwdriver,etc. if motor turns over the relay is bad. Chaz Moto DC
3helpful
Yamaha big bear 400 will not start wilth electric started will start fine with pull start has comp,fuel and spark
Sounds like a problem with the starter, could be a starter fuse, relay or solenoid. The start cicuit wiring could also be damaged. If you can pull-start the motor, and it runs fine, you have pretty much eliminated any problems with the motor. Check the wires running from the start button make sure they are intact, also trace them and look for around a 1" cubed black box. This is the relay, when you push the button, if its working, you will feel the box click. Also locate the starter and do the same thing. If you feel or hear the starter click, the solenoid is working. The battery voltage could also be too low to energize the starter motor. Could also be a battery or alternator issue. Check the battery voltage and for any sounds coming from the bike when you push the start button.
'xj600s (1995) cuts out when warm
air gap on electronic ignition or tdi unit or carbs want cleaning
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
