Question about Numark TTX1 Turntable
Numak ttx1 turntable
Hi both of my decks have stopped working they wont start up at all has the motor burned out?
  • munrohome May 14, 2009
    they stopped working within 4 months of each other but with exactly the same problem sounds like there is alot of problems withthese decks wish i,d bought technics!
  • Alfie_G May 11, 2010
    Did they stop working at the same time? or have they both failed over a period of time?
  • 104 Answers
If they are belt drive then you can get replacement belts from **** Smith Electronics for under 30 dollars if they are direct drive then you could check the fuses if its not either of these you might have to replace the motors which is quite inexpensive anyway
Posted on May 23, 2009
The tone arm has been pulled off my deck how much will this cost to fix
If it is the TTx1/200 about $200. Have a look at this website for more details. Tonearm Base Assembly TT X1 200
Feb 09, 2016 | Numark TTX1 Turntable
Platter stops when i scratch and goes backwards sometimes.....had mind of it's own
Not really (and really not possible)
It's likely a belt drive deck and scratching with the motor still running on this sort can't really be done.
It's a fairly quick way to burn out the motor and wear out the drive belt.
If the deck is provided with manual overide for Motor Off or a Speed Neutral control that disengages the motor from the platen.
If a gear or direct drive deck there should be a disengage clutch control or a Speed Neutral setting.
Sep 16, 2011 | Numark TT200 Turntable
My Numark TTX Turntable turns on but wont spin when i hit the play button
It's probably the motor drive IC Chip.
Send it to us for speedy, cheap repair.
http://www.reflexdjsuperstore.com/Service-and-Repair-p11441/
Jul 12, 2009 | Numark TTX1 Turntable
Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Nov 04, 2008 | Numark TTX1 Turntable
Ttx 1 numark
hiya fixya...well i just opted,,,to take the thing to the repairs.the conclution is that the"platter rotation sensor " had burned out.sent the deck off today.will let you know the outcome,to maybe pass on this info to other ttx 1 users for near future....thanks for your responce.quote 35 quid just to confirm problem...but deducted from final bill of??????.westend dj staff are very helpful indeed where i puchased them from in the begining.
Mar 31, 2008 | Numark TTX1 Turntable
My tunrtable spins backwards :S
these motors are quite cheap. You can open it up yourself and see if any resistors are burned up. If not, contact numark parts dept and order new motor. quite easy to install.
Dec 06, 2007 | Numark BATTLE PAK v.4 Turntable
Just so you know, there is no actual 'motor' driving the platter. It's a direct drive unit, so it's made up of various circuits driving the unit.
With that said, anyone of those circuits could have gone bad. The good thing, is that most of the circuits (resistors, IC's, capacitors, diodes, etc), are relatively cheap ($2-10), the bad thing is replacing them, and finding out which ones are faulty. You could usually tell which resistors are burnt or caps are blown, but it's harder to test the IC's without the proper equipment.
This is not a cheap turntable, unless you think $300 is cheap for a turntable. Repair wise, your probably looking at about $80-120 for parts and labor. It's a well build turntable, and I think worth investing in trying to get it repaired. Just make sure you get an estimate before any work is done.
- TWEAK AV LAB
Nov 26, 2007 | Numark TTX Turntable
Both decks with same problem.
Nothing to do with the magnet. These are direct drive turntables, and more than likely one of the ICs shorted. Unusual that both shorted out at the same time, so the only thing I could suspect is a faulty power source - make sure all of your cables are free of any exposure to the inner power cable. Also, you might want to invest in a good surge protector (in the $150 range) to protect these babies... I know they aren't cheap. You will need to get them professionally serviced, there are no user replaceable parts inside. If you can't find anyone near you to service these, our company offers free return shipping for all Nationwide service, and if your in NYC, we offer free pick up. Oh, and we are masters with DJ turntables. Unfortunately, I don't think we can post our company information here, as I do not want to violate any agreements. So, with that said, do a search using the REPAIR SERVICE search option in FIXYA.com and go to the following section-> HOME AUDIO -> Audio Shelf Systems - we are listed there.
Aug 04, 2007 | Numark TTX1 Turntable
Numark TTX1 Turntable Logo
366 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
