Question about Karcher 2500 PSI Pressure Washer
Electric Pressure Washer
I have a minimally used pressure washer rated at 1750 psi and electric.
AFter  plugging in the supply hose and power, I turn the unit on and it starts for a second to pressurize the system (as it usually does), but then when I press the nozzle, nothing happens; the motor doesn't start.  So if I unplug the water supply and power and let it sit for a few minutes, then do it all over again...the same issue happens...it starts for a second to pressurize the system then stops.  The unit is clean and no rust.  I'm not sure what component makes the unit trip off line.  Help!
  • karcherhater Mar 30, 2008
    Karcher 3.92M no pressure, brought to an authorized repair shop . They said parts unavailable for this model, No rust internally 2 years old stored inside.
  • Anonymous Jun 08, 2008
    I have a small electric 1400 psi washer. It did exactly the same thing when I started it. Expect it never started again, even after unplugging everthing and replugging.
Hi Your problem is your unloader pressure valve switch.It is a cylinder that moves up & down inside a housing,. activaded by water pressure.Inside the cavity of the housing is dirt on the wall of it.Thats your problem.Once you clean the cylinder wall & apply some water grease ,problem gone.Your problem is not the switch.
Posted on Feb 14, 2008
Try running the machine without the hose attached if the machine runs ok then it is probable the there is a blockage in the nozzle if the the machine still cuts out then the pressure switch will probably be stuck or faulty this switch will be inline with the on/off switch and the motor it can be checked using a multi meter after dissconecting the power.
Posted on Jan 02, 2008
SOURCE:
How to work a pressure washer?
hook up the water hose before turning electric on have the hose supplying water to it low pressure these units cant take full pressure like over 60psi, thenturn the dial to where you want andconnect power use 3 way adapter prong outdoor style extension with a good outside coded plug receptacle of course
Apr 04, 2016 | Karcher K 2.56 M 1,500 PSI 1.3 GPM...
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Pressuer washer not turning on
Inside machine are safety switches, you probably have a stuck on. Take apart, plug in and test with a tester to see where power is not getting to. I am guessing a safety switch is stuck.
May 02, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher 1750 psi electric pressure washer is making in/out loud noise when switch to On and idling not pressing washer trigger.
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | Karcher 1750 psi Electric Pressure Washer
I have a durabuilt DB1404 and when i'm spraying, the power washer doesn't want to keep going. It goes and stops. I tried getting the air out and that didn't work. What else could i try?
This sounds like you have an inadequate supply of water to the unit. Make sure your supply faucet is turned all the way on, use a 5/8 or 3/4" hose from the faucet to the unit, and use a smaller tip on your spray nozzle to minimize the amount of water you are using when working.
Jan 04, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Kenmore elite top loader washer has LF error message
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 19, 2009 | Kenmore Elite 45986 Front Load Washer
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Craftsman 1800 psi pressure washer won't start
disconnect the hoses to and from the machine and the try it.
the machine might have a blocked nozzle in the lance, of so get a paper clip and clear the jet backwards
Jun 23, 2009 | Karcher 1750 psi Electric Pressure Washer
WASHER STOPS AND SAYS LF
Apr 30, 2009 | Washing Machines
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
761 people viewed this question
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
