Question about Tripp Lite Lite SmartPro DataCenter 5000HW (SMARTDC5000HW) UPS System
TRIPP LITE SMARTPRO DATACENTER UPS MODEL:5000HW NOT WOKING
I received a Tripp Lite 5000HW SmartPro DataCenter UPS that was soaked with water during a flood I stripped it down and cleaned it with CRC and reassembled it and it worked .
I connected it to my home and it was working during a poweroutage for about 2 hrs with Computers and Refridgerator on.The Data cable was connected to the computer and the UPS software was working satisfactory.
One day I noticed when I tested it with only one computer alone it was causing the Computer to restart when it sensed a fault in the AC power.
and and another time I heard some popping sounds when I had a 200 watt Slodering Iron and another light load connected to the output.It remained working after but I noticed a slight varriation in the humming sound it normally makes. I then disconnected it and found that some inverter MOSFET Transistors and Resistors were damaged.
I changed the defective transistors and resistors and all the relays because I had always suspected the relays were giving me problems.When I tested the unit the 230 volts AC was not being able to connect to the UPS but it was working on batteries.
Could you help me to solve this problem I tried Tripp Lite for help but the unit does not have warranty and they do not give out Circuit Diagrams to customers.
If i get a Circuit diagram it would be helpfull even just a chassis wiring to make shure that all the wires were connected to their right places.
Do I have to play around with the input voltage to get it to start charging the batteries?
Regards
Godfrey Archer
http;//www.m1gy.com Comment posted on May 12, 2009 Re:Tripp Lite 5000HW SmartPro DataCenter
I double checked the wiring and I cant see no problems .When I switch the system switch on the battery charger is not charging and the battery status light is solid Red says that the battery is below 25% charge but I know that the battery is ok because it reads 39 volts DC and the same battery works ok with another UPS.
However I do know that the large transformer is not getting power from the input 230 volts and the regulating light is showing that the regulator is working especially when I switch between 208 and 240 volts .When I switch the power on Button the three green lights comes on to the right odf the UPS but you get no AC voltage output.
Colud you assist me please.
Regards
Godfrey Archer
  • garchers May 20, 2009
    I re- installed back the old relays and the unit worked with 235 Volts AC input with the UPS voltage set at 240 Volts and after around five minutes of relays switching.
    With the System switch on and the unit in charge mode the battery voltage increased from 39 volts to 40.7 volts, after leaving the UPS overnight. When I first got it working it would go to 45 volts.
    Right now the Line Power standby light is flashing green to indicate that AC is not available at the outlet.
    I would like to know where the adjustment is for the charging voltage.or current?
    Regards
    Godfrey
3 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: TRIPP LITE UPS MODEL:5000HW WILL NOT START
Hi Godfrey,
Its very difficult to get a circuit diagram indeed. Did an extensive searching . Not sure if this would help you . Please click on the link bellow.
http://images.google.com/images?gbv=2&hl=en&sa=1&q=tripp+lite+circuit+diagram+for+UPS&aq=f&oq=
Now once the page opens you would find a number of circuit diagram. You can click on the required image to enlarge it.
Thanks
Posted on Apr 30, 2009
SOURCE: How to configure and setup
hold off button until in bypass mode comes on. to setup hold scroll and select buttons down together, until it goes to setup mode. make selections. exit. then hold on button until it beeps and comes on through diagnostics.
Posted on Mar 12, 2010
How to fix broken smartbro simcard terminal
Buy the new simple terminal from eBay and solder a new one on. Check pins if pins are bent straighten with a flat head screw
Jul 24, 2014 | Tripp Lite Lite SmartPro 1050RM UPS System
I buy a Smart1000 LCD UPS system, I plug in the UPS it was on for a couples of day then y turn off, when I try to turn it ON it doesn't work. What I have to do, please help Thank you
I have had the same issue with mine. Try to hold the power button down, until you hear a loud click on the UPS. If that doesn't work, the battery or the relay on the UPS may be defective. Hope that helps!
Feb 28, 2011 | Tripp Lite SMART1000LCD SmartPro UPS...
How to configure and setup Tripp Lite SmartPro UPS "Out of the box"?
Mar 10, 2010 | Tripp Lite Internet 750U (internet750u)...
Smartpro UPS dead
APC UPS not turn on if battery are dead (zero volt) or un-plugged.
Oct 16, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
Rack mount tripp lite ups model# smart 1400rm came in, 2 yellow leds lit, makes clicking sound, and will not fire up off an ac line, replaced one leaky cap and r64 is burnt need the value of that resistor...
Hi:
I have same problem but you (and me) are in luck because I have another Smart 1400RM working!!! Just need a couple of days to dissasemble because needs to take out from operation and put again on work. My damaged one is worst than yours because an IC exploded, same time I will check for this IC part number too. We will keep in touch
Jun 13, 2009 | Tripp Lite Lite SmartPro 1400RM UPS System
Hi Godfrey,
Thanks
Apr 30, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
Tripp Lite Lite SmartPro DataCenter 5000HW (SMARTDC5000HW) UPS System Logo
123 people viewed this question
Top Tripp Lite Computers & Internet Experts
 Kevin Kershner
Kevin Kershner
Joseph Hoffmann
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
