Question about Medion GoPal PNA220XL Portable GPS Receiver
Medion GPS PNA315 would not turn on , and battery would hold any charge. I replaced the battery but the unit will still not start. The battery has charged, but will not start. The on/off switch has now broken and bent into the GPS unit. My Medion GPS is better than any other GPS that i have ever used. Thank You Laurie Kenny.
  • 3,230 Answers
First of all clear all the pin points where battery tuch to gps.
and try again...
post further comment for more help..
Thanks
Posted on May 13, 2009
Will not hold a charge and will not turn on its tnd 510
Unit draws it's power through the battery not the charger. Don't ask me why i have no idea. If the battery will not hold a charge then the unit will not turn on. Battery is replacable. Make sure you do not throw out the battery since you might have to remove the plug on the old battery and put it on the new one. I don't know if you can get the specific battery for this unit but it is a common battery battery. Should be just the plug that makes it UNIQUE
Sep 18, 2013 | Rand Mcnally TND 710 GPS Receiver
MY GARMIN RESPONDS BUT JUST SHUTS DOWN AFTER IT WORKS JUST A BIT ANY ANSWERS?
The battery seems to be weak and is not holding a charge so the little strength it has is what it uses to power it up to the extent where it works a little and goes off.
First reset the unit before you carry out some tests, to reset the unit, you need to charge the device for about 2 hours before powering it on, then you press and hold the power button for about 15 seconds to see if it will still do the same. If it does, then you need to carry out some tests on the battery, the charger and the device itself.
Try to charge the gps device for about 2 hours then try to turn it on. If it does not come on, then it means the battery did not get charged. That can be a problem from either the battery or the charger or the charging port.
First test the battery by fixing it in another gps and charging it for about 2 hours then turn it on. If it powers on the gps, then it means the battery is okay, but if it does not turn it on, then it means the battery is weak and cannot hold a charge and the solution is for you to replace the battery.
Next you test the charger by trying it out on another gps device, if it turns it on, then it means the charger is intact but if it does not turn it on, then the fault is from the charger.
Finally, test the gps itself by trying to charge in by connecting it to the computer using the USB cable, then you turn it on, if it does not come on, then it means there is a problem with the connection port or there is an internal problem or something with the unit.
Hope this advice was useful to you.
Jan 07, 2011 | Garmin nuvi 650 GPS Receiver
My garmin nuvi 255 turns on for a few seconds after the start up screen then shuts right off
It simply means the device is not properly charged, that is why it is not powering on beyond the start up screen.This problem only comes up when the battery is not properly charged, therefore not being able to power up the gps beyond the loading map page. Try to reset the unit by holding the power button for about 15 seconds, it will restart the unit, once it restarts it, check if it will get pass the loading map page. Then you try to back up the software on a computer, format it and restore the software back on the unit. If that does not help, then you carry out the following tests.
Jan 06, 2011 | Garmin nuvi 255W GPS Receiver
While plugged in, my Garmin c530 will shut down immediately after it says "loading maps". Why is this?
Jan 02, 2011 | Garmin StreetPilot c530 GPS Receiver
I have lost my software cd for medion gopal pna315
Google "medion go pal software torrents" (need a multi share to download I,e utorrent,limewire,etc
tc
Sep 28, 2010 | Medion GoPal PNA220XL Portable GPS...
Tomtom one will not turn on. Will eventually come on for 2 seconds then goes off again. Power cords work on other devices and outlets work on other devices. Have tried repeatedly to 'reset' and hold...
Powers on then off is usually a sign that the battery in the unit is no longer holding a charge, i would suggest that you check the battery and make sure that it is holding a charge and if not, change the battery out, these gps units have a dead circuit in them, if the battery is no good then usually the unit will not turn on, also for testing purposes if you pull the battery then try powering up the unit it may turn on, if this happens then you know the battery needs to be replaced.
Jun 11, 2010 | Tomtom ONE GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Gps dosen't hold a charge. ac power charge, or mobil charge
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
Jun 06, 2009 | Nextar Q3 GPS Receiver
Medion GoPal PNA220XL Portable GPS Receiver Logo
104 people viewed this question
Top Medion GPS Experts
Are you a Medion GPS Expert? Answer questions, earn points and help others
