Question about Philips Magnavox 27MS343S 27" TV
Tv goes on fine, sound good and pic green light receptor on tv starts blinking and we lose pic sound still good. When we tap the light on tv pic comes on fine for a while then same thing happens again
Our tv goes on fine, pic and sound just as good as always...but a little while later the receptor light lower right hand, which is green when on, starts blinking, we lose pic, the sound is fine....then when we tap the receptor light the pic comes on for some time before it happens again...though it has been happening more times than not.
    President:
  • 814 Answers
This television is having problem with intermittent tuner reception.The tuner is the signal processor for the television. The video section is intermittent. This could be a simple matter of cold solder joints that can occur over time due to heat expansion and contraction.This causes the metal in solder to expand and then when the television cools down, the metal that is expanded cannot contract.The solder joints then becomes intermittent. All televisions suffer from this problem.Since you are able to still able to receive the video signal, there appears to be no component damage. You will need to take this television in to a service center and have them rework the solder on all the areas around the tuner section of the television and any other areas that may be susceptible to the problem due to overheating.You can call Magnavox customer support at this telephone number 1-800-705-2000 and ask them for the location of a service center in your area. Or take it in to a local repair center and have them test and service the television for you. You can also try taking it to a school where they are teaching electronic repair and ask them if they will work on the television for you.They will usually do the work for a cost of parts and a small labor charge. Call them first to make sure they will help you and tell you how you can get the television serviced This may not be the only problem you are having with the television. That is why you need to have it tested first. I hope this information help you with your problem.
Posted on Jun 03, 2009
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Standby/power button blinks with no picture or sound
id take it and have it repaired. people on here can tell you what they think it is but no one knows for sure what is causing the problem. a repair shop can guarantee the repair.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
