Question about Epson Stylus Photo R300 InkJet Printer
Parts inside the printer have reached the end of their service life is the error message that was posted on the printer.
Try pressing and holding in for 5 seconds the power button, the low ink or paper button, and the stop button all at the same time,it may reset the printer.
Posted on May 15, 2009
    Sergeant:
    Champion:
  • 240 Answers
Try to clean the inside part of the printer...maybe it suffered loss connection.
Posted on May 13, 2009
  • Ramel Mayormita May 13, 2009
    try also to dis connect cable and reconnect them..
3 Suggested Answers
  • 5337 Answers
SOURCE: Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
Posted on Jan 29, 2010
  • 857 Answers
SOURCE: the printer is giving me a message that the parts
Please try these steps:
1. Unplug the power and USB cables from the printer.
2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
3. Unscrew the screw at the back of the printer.
4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
7. It is recommended that once you have done this, you let them dry.
8. Now return the pads back into the printer.
9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
11. Download and install the SSC Service Utility for Epson Stylus Printers.
12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
13. If it asks if you replaced with the pads; say “YES”. Then close the window.
14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
This should do it.
Posted on Mar 03, 2010
Service required
This error occurs when your printer thinks the ink absorber in the bottom of your printer is saturated with ink. It can be reset pretty easily with a free utility.
I have written a short article and made a video guide on this very message. they can be found here: http://www.refreshcartridges.co.uk/igloo/clearing-parts-inside-the-printer-have-reached-the-end-of-their-service-life-on-epson-printers/
Hope this helps.
Dec 27, 2012 | Epson Stylus Photo R300 InkJet Printer
Parts inside your printer are at the end of their service life. See your printer documentation.
Q: What should I do if my printer driver displays the message parts inside my printer are reaching their end of service life?
A: See the Epson Ink Pad Reset Utility page.
Epson Ink Pads Reset Utility
If your product is displaying an end of life service message, please view and complete the required information below to proceed.
Please explain the message I am getting in my printer driver that says parts inside my printer are reaching their end of service life.
Like so many other products, all Epson consumer ink jet products have a finite life span due to component wear during normal use. At some point, the product will reach a condition where either satisfactory print quality cannot be maintained or components have reached the end of their usable life. This is the normal product life cycle for highly mechanical devices like printers. This message is a warning that certain parts have reached the end of their usable life and that your printer will no longer work until it is serviced.
What parts are we talking about?
The message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable life.
Why does my printer stop functioning when I get the message?
Epson is committed to ensuring the proper operation of all our devices to minimize the risks of property damage or personal injury during the lifespan of the product. The printers are designed to stop operating at the point where further use without replacing the ink pads could create risks of property damage from ink spills or safety issues related to excess ink contacting an electrical component.
Is there anything I can do to continue using my printer?
Epson recommends replacing the printer, but if you want to continue using it, Epson recommends having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. Please note that replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Epson does not recommend ink pad replacement by users without technical training or resetting the Ink Pad Counter without replacing the ink pads.
Note: This utility is for Windows XP and Vista operating systems only. We hope to develop an option for Mac users as well; however, we do not have an ETA or the OS requirement at this time.
To download this utility, please complete all fields below, select the agreement check-box and click Download. Required fields are noted with an asterisk(*). Some models may require you to be redirected to another website to finalize the process.
Go here to complete the agreement and download the utility:
Dec 09, 2010 | Epson Stylus 1400 InkJet Photo Printer
Parts inside end life
Go to this link to complete the agreement to recieve the Epson Ink Pad Reset Utility.
Trust this is helpful. :)
Dec 09, 2010 | Epson Stylus Photo 1400 Printer
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
ERROR MESSAGE EPSON 925
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Feb 27, 2010 | Epson Stylus Photo 925 InkJet Printer
" parts inside your printer are at the end of their service life.
This usually happens when the waste pads become full and need to be replaced.
You can try to do it yourself like this guy did on his printer:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
you can actually just use the software to reset the printer but eventually the pads will overflow and start to leak.
The last option is too take it to Epson and ask for a quote.
May 14, 2009 | Epson Office Equipment & Supplies
Parts inside your printer are at the end of their service life. See your printer documentation Parts inside your printer are at the end of their service life. See your printer's documentation for details
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
Feb 26, 2009 | Office Equipment & Supplies
Service required error
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
http://www.octoink.co.uk/store/pages/Epson-CX6600.html
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
Feb 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
