Just recently my oven stopped working and an "ERR" shows in the temp display. The oven is not operable. I have unplugged in hopes of resetting with no luck. The oven is less then 1 year old, but I cannot find the bill.
-   Oster toater oven 6248 is 16 months old and an err code displays in the temp screen after running for 1 minute. Has anyone got a solution. -   micantco
Feb 09, 2009
-   My unit is doing the same thing. It is one year, two weeks old. Replacement seems to be the only solution. I will not buy another Oster-   widgielk
Jan 25, 2009
-   Well, I should not be crying as I have the same problem, err problem, but mine lasted for just over 2 years! Looking at other comments, I think I got a better unit! I will never buy Oster... -   Guest
Dec 13, 2008
-   I encountered same problem today. No reason, just failed with ERR message. Tried to unplug and used air dust blower to blow all internal connection points. No luck!
Vote with your feet! I will never buy Oster again! My unit was also only 18 mo old. why are these digital keypas so frustrating. I would just as soon have a manual ability to operate-   ronald1b
Dec 08, 2008
-   Same problem different model; only about a year old. Piece of junk; never will I buy Oster again.-   jodykt
Dear Sir/Madam The house I bought has an old-ish philips 'System 600' oven. I can't seem to set it...
(More)
Dear Sir/Madam The house I bought has an old-ish philips 'System 600' oven. I can't seem to set it to the right time or figure out how the timer works. I have looked online to see if I can find a manual for it, but without success.. Any help would be much appreciated! Thanks and best regards Masrtin
DeLonghi xr640 ex LI1. Top rear heating element broken/snapped in half. How to replace? Are ends of...
(More)
DeLonghi xr640 ex LI1. Top rear heating element broken/snapped in half. How to replace? Are ends of element soldered or welded? Where can I buy replacement?
i have an oster toaster that worked for about 8 months, then just recently it shows this error (err)...
(More)
i have an oster toaster that worked for about 8 months, then just recently it shows this error (err) aftr toasting for a min. do you know what i can do?
Hi there, I'm asking fron Venezuela. I have a convection over Oster 6248. It beeps and shows ERR on...
(More)
Hi there, I'm asking fron Venezuela. I have a convection over Oster 6248. It beeps and shows ERR on the screen. I don't know what to do, thanks in advance
My toaster oven starts but shuts off shortly after starting and displays err. Will not work on any...
(More)
My toaster oven starts but shuts off shortly after starting and displays err. Will not work on any setting
Same problem and Oster support refused to talk to me as I couldn't find the receipt. I really did like my little oven but intend to vote with my feet and never buy another Oster product after their awful customer support. With todays economic crisis affecting all consumer product areas you'd think they'd be a little nicer to their customer base.
Comment by Guest, posted on Nov 12, 2008
Oster model 6248 same problem....ERR and beeping in toaster mode. About 2 yrs old. Bought at Bed Bath and Beyond.
Same problem here. "ERR" message and beeping. Oven won't work. I've tried unplugging and replugging, hitting it, and yelling at it. It worked for less than 1 year. I'm not in love with Oster right now. My model is actually a 6248 but looks virutally identical to this one.
Same problem here. Bought mine at costco. I wonder if they take it back?
Comment by Guest, posted on Jan 02, 2008
Same problem here, i've had mine for 18 months now. Err and beeping sound... I unplugged too for the night, tried to use it this morning and again - it doesn't work
err message when in toast setting - beeps and goes off. tried unpluging - does not work. let it go and it resets itself in bake mode. argh!!!! it is a little less than a year old.
I have the same issue, digital display says "err" and it beeps, but doesn't work. Mine is also about 11 months old, and I can't find my bill either! Argh! Have also unplugged hoping to reset, and looked for a reset button, but no luck.
