Question about Electrical Supplies
Need to retime generator.reset and cleaned valves and lost timing.can you assit.
  • monjohn8 May 14, 2009
    powerfull inverter.model number xg-sf300.
  • 3,230 Answers
First of all you need to provide the model number and make of your generator so, i can help you.
Thanks
Posted on May 13, 2009
  • Mukesh Kumar May 14, 2009
    The only way to restart it is to knock the power off at the circuit breaker to reset it.
    Thanks
My ryobi 2200 generator rebs hi and low over and over it works but i feel it might turn off
You need to clean carburator. The bowl float opens and closes the pin valve. The float may have a leak, if gas inside float, it needs replacing. Or the valve is sticking. Get a good carb cleaner product at parts store. If its very bad you may need to take carb apart and soak the parts to clean them. Make sure you are turning off gas valve when not in use. You should turn off gas valve and let the motor run out of gas before using kill switch to drain gas from carberator each time its run. Then this won't happen. If no gas valve, buy one and install. Its worth it.
Jan 20, 2014 | Electrical Supplies
Bike wont start
What state are the spark plugs in, double check positioning for timing
Jan 21, 2013 | Motorcycles
My egr valve wont open complete is there an vacum assit available??
Do this egr valve is electrically operated. If your not getting enough egr flow .you can remove the egr valve and clean the passage way. Un-pluging the egr and taking the two 10mm bolts out of the egr valve. You can the use a pipe cleaner and carburetor cleaner to clean the passage way out of the excess carbon.
Aug 30, 2010 | 1995 GMC Jimmy
How do i retime diesel pump after belt snapped
YOU HAVE TO RETIME BY REMOVE AIR CLEANER.REMOVE CYLINDER HEAD COVER.AND TIMING BELT COVER.TURN THE ENGINE TO TDC OF THE NUMBER 1 CYLINDER HEAD.YOU NEED TO INSERT A SETTING BAR INTO THE SLOT ON THE REAR OF THE CAMSHAFT.VW TOOL 2065A OR EQUIVALENT TO HOLD CAMSHAFT IN PLACE.WHEN YOU RETIME THE INJECTION PUMP YOU HAVE A PIN ALIGNMENT SLOT ON THE SPROCKET HUB IT SHOULD BE AT 12 OCLOCK POSITION.YOU HAVE TO INSERT LOCK PIN TO HOLD SPROCKET IN PLACE.WHEN YOU INSTALL THE TIMING BELT.YOU HAVE TO PRIME THE INJECTION PUMP.BY HOOKING A HAND HELD VACUUM PUMP TO THE RETURN LINE FITTING AND DRAW FUEL INTO THE INJECTION PUMP TO KEEP FROM DAMAGING PUMP IF PUMP IS DRY.THIS WILL GET VAN GOING BUT THE DEALERSHIP STILL HAS TO RETIME TO INJECTION PUMP USING A SCANNER.IF VAN DONT CRANK BROKEN BELT COULD HAVE DAMAGED THE VALVES AND PISTON.
May 05, 2010 | 2001 Volkswagen Eurovan
How do I retime the crank pulley on a 2.3 ford fusion engine 2009?
The crank pulley is not keyed on this engine. There is a timing peg that needs to be installed and the valve cover needs to be removed to set the camshafts with a timing plate. Take it to the dealer before you damage the engine. This engine is a non-freewheeling engine. The valves will contact the pistons if not timed correctly.
Aug 17, 2009 | 2009 Ford Fusion
Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
May 18, 2009 | 3M MP 7750 Multimedia Projector
My timing belt broke
When A timing belt breaks, the best way to see if the engine is still good is to retime the motor, put a new timing belt on without the covers or anything else in the way or replaced, (that way you can see the belt and timing marks moving) and do a compression test one each cylinder. you're not looking for compression to be at specs, you just need to have a compression reading on each cylinder. if you have compression in each one, finish the job up and it should work. if you have no compression in one or more cylinders, chances are you have a bent valve. that involves pulling the heads off and having them gone through.
hint: To reset the timing on the engine move each gear just a little at a time swtiching between them each time. If you start to feel any binding that feels like you're hitting a piston, you probably are. it's normal to feel some tesion from the springs, bout you can still turn the gear with a little effort. it's tricky to describe the difference, but once you feel the spring pressure, you'll know what the feel of a valve on a piston feels like. if this happens, just move the crank a little bit and then go back to the cams. take your time and you'll be able to get the motor re-timed.
Jan 27, 2009 | 1997 Nissan Quest
Pilot ligt wont stay light
My suggestions,
take the electrical wiring off the terminals of the gas valve one at a time, and clean the contacts with a food grade electronics contact cleaner and degreaser. Make sure all wiring is tight, not loose fitting, and clean. The thermo coupler, or sometimes used thermopile (multiple thermocouples in one) generates a small amount of electrical current when heated. The oil residue on a gas valve's electrical contacts SHORTS OUT THE MINUTE CURRENT GENERATED not giving enough current to hold the valve open.
The next thing, how high is your pilot set? If the flame is not striking the thermo pile properly, if its not directally in the flame, it will not generate enough current to hold the gas valve open. Sometimes a dirty thermo pile just cleaned up with sandpaper will work again (accumulated material acts as an insulator)
If you have access to a very high end electrical meter that is capable of measurung MICRO AMPS (very few) then you should check the actual current ouput of the themo pile.
Another thing, the gas valve solonoid MAY BE DEFECTIVE! IF YOUR THERMO PILE is of the screw in type vrs screwed on type, remove the gas valve end, degrease the inside and also that of the thermo pile surfaces, then use the CLEAN errasser of a pencil to clean both the inside of the gas valve connection, and also that of the thermo pile contacts. NO ERRASSER RESIDUE CAN BE LEFT ON EITHER SURFACE! Do not touch these contact surfaces with your hands because even the resistance of the body oil on these surfaces can mean the differance between it working or not!
The thermo pile or a thermo couple generates a minute amount of current that holds the gas valve on.
PS: and that didn't even cost you a dime, I'm off to an emergewncy service call to fix yet another McDonalds deeping fryer (don't call them beeping fryers cause they beep either!!!)
Nov 24, 2008 | Pitco Frialator SG14 Deep Fryer
Software download
want to use camera for pc cam but lost cd need assitance
I have a optimus digital video cam cat. no. 16-3845 for which I lost the cd to download my pictures from the camera. can you help?
Aug 29, 2008 | Cameras
JVC KD-G720 car stereo - how to change the time?
jost let the radio on its wl shaw time & it teks time
Jun 30, 2008 | Car Audio & Video
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
