Question about Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
Nexstar My Nexstar 3 has 232 Gb. The blue light keeps flickering on and off when I turn Nexstar on Thuto (thutom@yahoo.com)
  • amnp Jan 09, 2008
    I had the same problem... I turned off my external drive when it was
    turning very fast (faster than usually because i was earing the noise,
    not the one it makes usually...) than when I tryed to turn it on the
    day after the blue light was flashing and my computer did not reconize
    it. So THANKS for the ''cue'', IT'S NORMAL'' I've just plugged again my
    external case into my computer, then turn it off (the drive), turn it
    on, and it worked! EASY!
  • brettttreb Apr 02, 2008
    Why does the blue LED keep flashing, is it dead or fixable, all me stuffs on there
    Novelist:
    Champion:
  • 382 Answers
Its normal, and is the signal showing the drive powering/spinning up and down. The drive spins at 7200 rpms, when you power it up or down, its switches onto the speed that best suits  what it's intended to do.
Posted on Oct 22, 2007
Cant connect to the wifi for camera clock and blue light not blicking have push the reset button but nothing happens
Using your preferred search engine, type YAHOO MAIL FORGOT PASSWORD and you may find some helpful tips.
If your mail suddenly stopped working, your account may have been hacked. Yahoo mail should have ways for you to get the account back using any questions you may have answered, alternate email address, text messaging, giving the last password you remember working.
Dec 12, 2017 | The Computers & Internet
Why do ABS and BRAKE lights blink on and off?
Search Results
    Brake Hydraulic System Red Warning Light - RepairPal
    repairpal.com > Auto Care Advice > Warning Lights
    If the red brake light blinks, or comes on and off intermittently, and there is no change in the feel of the brake pedal, then have the vehicle properly diagnosed by ...
    why does my brake light come on and then go back off? ' Yahoo Answers
    https://answers.yahoo.com/question/index?qid...
    Jan 23, 2012 - today i was driving and my brake light came on and then went right backoff and was ok. my brakes work fine. ... Best Answer: Check your brake fluid, and top it off. There is a sensor that gets tripped when the fluid is low, and then goes off when it is refilled. (!) BRAKE light flickers occasionally while driving???!!? - Yahoo ...
    Oct 6, 2010
    Brake light flickering on and off? ' Yahoo Answers
    Sep 25, 2009
    My parking brake light keeps turning on and off? ' Yahoo Answers
    Feb 6, 2009
    My car's brake light turns on and off every now and then while I ...
    Dec 3, 2008
    More results from answers.yahoo.com
    Brake Warning Light On, then Off - Car Talk
    community.cartalk.com/discussion/.../brake-warning-light-on-then-off
Jan 30, 2016 | Cars & Trucks
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I have a 1999 Honda Shadow 750 ACE the marker lights are flickering and it backfires on decell after steady throttle, what could be causing this? I have tuned it up and cleaned the carb but it still does...
To help stop the popping replace the copper head o-rings and muffler to head pipe seals. Backfiring is typically caused by air leaking into the exhaust and igniting unburned gasses. Flickering lights indicate bad wire connections/grounds. Honda grounds the turn signals through the green wires. You will probably have to take off the seat and open up the headlight bucket. Try unplugging and replugging the orange,blue, and green wires going to all four turn signals. This should take poor contact and grounding out of the equation and sort out your flickering lights. Also go to the fuse box and take out the fuses one at a time and reinstall them. Make sure that the end caps of the fuses are not loose, if so, replace the fuse. Broken ar cracked fuses on older bikes can cause head scratching problems where there aren't any. Make sure that all your turn signals are grounded through the green wires.
Sep 05, 2010 | Honda VT 750 Shadow Aero Motorcycles
When I try to turn my plastation 3 on the green and blue lights come on then a yellow light flickers and the plastation turns off
Sorry to hear that you have the YLOD (Yellow Light Of Death)
If you dont have any warrenty left on your ps3 then take a look at this guide how to fix YLOD. [ Link ]
If you still have warrenty left i advise you to use it.
I hope this can help you, best luck from here. :)
Oct 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Vantec Nexstar 3 HD not being recognized on comp
Hi, I had this same problem - blue light flashing and the drive not being recognised.
The problem was with the power cord, not the drive.
I solved the problem by unplugging the connection on the power cord between the outlet end and the power brick section, and re-plugging them after flipping one of the ends over.
The drive was now getting power correctly and spun up and was recognised as usual.
Apr 17, 2009 | Vantec NexStar 3.5in External Hard Drive...
NexStar hard drive doesn't recognize its size
It may be crashed....use [Nucleus Kernel for FAT and NTFS ] software...
Oct 11, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Celestron Nexstar 11 GPS Electrical problem
The Nexstar11GPS group on Yahoo.com.
http://tech.groups.yahoo.com/group/NexStarGPS/files/n11gpselectronics.zip
Nov 06, 2007 | Celestron NexStar 11 Telescope
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case Logo
1,289 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
