Question about Bose Companion 3 Computer Speakers
Volume control sticky
Rubber
Yamaha np 32 some keys faint in response
This is normally caused by dirty or worn contacts.
Simply open up the keyboard and replace the contact rubbers when the sensitivity has been lost.
There are 4 different rubber contacts depending on which notes are not working
WJ231101 RUBBER CONTACT 16N-2M OCT 2M-55
WJ231200 RUBBER CONTACT 16N-2M OCT 2M-45
WJ231301 RUBBER CONTACT 16N-2M 76H 2M-45
WJ231401 RUBBER CONTACT 16N-2M 76L 2M-55
Nov 12, 2016 | Yamaha Music
The black rubber top for the rubber joystick on my wheelchair keeps falling off where can I purchase a new one? It looks like a black rubber nipple
superglue holds rubber to metal very well , just don't use to much to run down inside switch but stays on tip
they now mfg a gel superglue for this very application (no run/no mess)
Jun 01, 2015 | Health & Beauty
How to replace the rubber seals in the poptop roof of a jayco 2009 expanda and where to buy the rubber
The correct rubber will be available from any jayco caravan dealer and you may get the same section rubber from a rubber retailer such as clark rubber
Oct 26, 2014 | Cars & Trucks
Its the small rubber bit under the space bar
ok you need to unclip the spacebar carefully take off the rubber and replace with one from another keyboard use rubber solution to bond it in place making sure that the center on the board and rubber pad are free from dirt or glue, a good place to dource the rubber pad from is old mobile phone keypads or old childs toys with rubber buttons one of those cut to size and glued to under side of spacebar would be perfect, hope this helps and good luck.
Jun 21, 2013 | HP Mini 210-1030NR 10.1-Inch Black Netbook...
Rav4 sunroof leaks because of worn rubber seal and not because of clogged drain hole
most upholsterers should be able to help here If not go to a rubber dealer that sells sponge rubber etc as most have a good selection of auty trim rubbers that you can fit yourself. The best glue is loctite 406 Be careful as it is a super glue
Jan 10, 2013 | Toyota RAV4 Cars & Trucks
Can i replace focusing ring on nikon 18-200 lens
Rubber focus ring can be purchased in ebay.
The rubber ring may be attached to the lens with glue. Use denature alchohol between the rubber and lens to remove the rubber ring. It can be stretched little. Once removed, clean any glue on the lens and stretch the new rubber ring and install.
Nov 01, 2012 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Bicycle Child Seat install has a rubber piece hanging in back
The rubber piece is designed to lock the tung on the back of the seat to the rack. To get it in place you need to bend the tung down until you can insert the rubber piece over the tung and under the two fins so that when you release the tung the rubber is locked into place. You will likely need to bend the tung down quite a bit. The rubber piece has two circular ridges that should be between the two fins that it is pressed into. These ridges will prevent the rubber piece from sliding out.
So basically, bend the tung down and press the rubber piece into the slot that is created. It will start to become clear once you get this far. Just make sure those ridges on the rubber are on the inside of the fins.
Mar 12, 2009 | Carrier Cycling
Bose Companion 3 Computer Speakers Logo
368 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
