Question about ASUS P5RD1-VM Motherboard
I hav d same motherboard which was workin fine but now it stopped detecting my pata hard disk which was primary. but sometimes it detects it n den while i m working, suddenly my pc turns off n it doesnt detect the hdd. i tried changing d cable bt it didnt help. pls help me!!!!!
  • Yannick Verhoog May 11, 2010
    Does this also happen to other harddisks?
    You could try putting another in to determine wether your motherboard or the disk is the problem.
  • 52 Answers
This is the connection problem. there is loose connector betn cable and your hdd. first remove the harddisk, connect cable, be sure that it is connect correctly. do connect it loosly. i hope. then your hdd work.
Posted on May 13, 2009
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
MB MSI K8MM-V, Unable to detect 80 GB primary HDD. What need to be done ? Update Bios ? Which one ? Ravi
If the BIOS cannot detect the 80Gb hard disk then it is probably faulty.
Make sure the jumper on the hard drive is set to MA (master), if this doesn't work set it to CS (cable select) If it still isn't detected by the BIOS then the hard disk is faulty and you need a new hard disk.
Mar 13, 2011 | MSI K8MM-V Motherboard
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
Primary IDE master not detected
Hi darchie_1213,
Power off the system & unplug the power cord. Open your PC case. To remove any static build up from your body, touch the metal bottom of the case before touching any internal parts.
It sound like the primary IDE data cable is loose or the power cable to the drive is loose. Try disconnecting both & than re-connect them. If that does not stop the issue, replace the data cable for the primary IDE drive. Click on the link provided. The site will explain IDE connections & the differences between a 40-pin IDE data cable & an 80-pin data cable. (Pictures included & lots of helpful information).
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
Try the above first. If the problem continues the issue could be the hard disk drive.
Mike
Apr 11, 2009 | ASUS P5V800-MX Motherboard
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
ECS K8M800 bios can't detect hd pata seagate
How you setting the jumper, pls refer to mobo manual book or HDD or your DVD/CD recorder. i gues your problem is in setting the jumper. thx
Jan 31, 2008 | EliteGroup K8M800-M2 Motherboard
Hard disk detection
try to reformat your hard drive
Jan 27, 2008 | Intel D102GGC2 Motherboard
ASUS P5RD1-VM Motherboard Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
