Question about Sony VAIO VGN-AR630E Notebook
My card slot is not working - Sony VAIO VGN-AR630E Notebook
We have tow nodes working as a dual shelf A & B. The control card in B is the main and working probably but the backup control card which is in A doesn't carry the load when we switch the load between...
The control card wasn't work between slot 1to8, they 're called universal card slots (UCS). The control card works only slot 9 or 11 for single shelf redundant configuration. While dual shelf redundant configration the control card works on 9 (shelf-a and shelf-b).
I think your problem was on B-control card. It doesn't support hot standby configuration.
ilker
Jul 15, 2010 | Alcatel Newbridge MainStreet 3600...
My card reader has stoped working how can i get it to read my memory cards agian
First check if other memory cards is working on the system so you can isolate the problem if the card reader slot is faulty or the memory card itself..If other memory card is also not working then we can say that the card reader slot is faulty..There are also 2 scenarios it can be the hardware itself or the driver installed on it..Check the BIOS of the computer is memory card slot is detected..If detected log on to windows and check device manager if card slot is properly installed..Update the driver if there's newer driver for the card slot..You can also try to perform system restore and pray it will work..If those steps don't work..You need to tear down the computer and take out the card slot and try to different known good system..If card slot still doesn't work..better purchase a new one.. Hope this will help..:)
Feb 02, 2010 | Microsoft Windows? Vista Home Premium...
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
Lenovo desktop pci express slot
it may that ur pci express slot not working. u contact ur graphics card retailer or go with the cpu to his shop.
Jul 01, 2009 | Lenovo GeForce 6200, (64 MB) PCI Express...
What is the function of expended card.how many band width of mux 3600 single shelf,doul shelf.27LC card suport daat limit.why we use expanded card in mux 3600?and DINC card use for how many data sopor
You mean Expander Card.
The original chassis was fitted with only 6 slots and thus the control card can only manage these 6 slot single bandwidth. (2Meg per slot). As the 8 slot chassis was develop it was I think cheaper to build a new card as to build a new control card to manage the other two slot (7 and 8). So the expander card was build and to extend the shelf to 16 slots you do need the expander card fitted with a +16 expander module so that you can manage both chassis and provide double bandwidth per slot (4 Meg per slot).
There are two types of DNIC cards, nl. 6 circuit and 12 circuit. This card must be fitted with a DSP module if you want to configure the ports for 128K. Only 26XX DTU’s will work with this card. This card and DTU’s has been discontinued.
The 27LC2 card is a 6 circuit card and only 27XX and 2751/2/3 DTU’s will work with this card. This card and DTU’s has been discontinued.
The replacement for this card is the 27LC3 card and 27XX and 2751/2/3 DTU’s will work on them.
The 3600 mux is a single shelf which can be extended to a dual shelf. Each slot using a expander+16 can deliver 4 Meg. If only a single shelf is used you can fit a +8 module on the control card to provide you with 8 slots and 4 meg per slot.
May 11, 2009 | Alcatel Newbridge MainStreet 3600...
Hi would my nvidia graphic card work on a pentium 4
Graphic Cards work when the card and the slot types match. Common slot types for Graphics cards are PCI,  AGP, PCIe1 and PCIe16. If your NVIDA (chipset name) card is the same type as the slot on your board the answer is yes. If it fits the slot, it will work.
Feb 17, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Card needing 2.2 compliant PCI slot work in 2.1 compliant slot?
Hi ginger_man07,
Yes. 2.2 devices are backwards compatible & will function with your 2.1 slot.
Enjoy ginger_man07!
Thank you for using fixya.
Mike
Jan 13, 2009 | Computers & Internet
Memory Card Slot Problem
Well, this problem may appear due to your memory slot is dirty. Try this simple solution first:
  • Off your phone (IMPORTANT!)
  • Open your phone back case
  • Find the memory card slot
  • Clean the slot (gold stripes) with a rubber eraser
  • Clean the messy
Should work by now.
Jan 08, 2008 | Nokia 6680 Handheld
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
Sony VAIO VGN-AR630E Notebook Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
